Old 05-10-2006, 12:20 AM
DaveB DaveB is offline
Rep: 11 Posts: 128
importing iges to Maxsurf
Hello all,
I'm trying to import an iges surface into Maxsurf from Rhino. I started with a simple surface of a hull but trimmed it and added parallel midbody. I used the ShrinkTrimmed command to trim the net defining the surfaces to their boundaries. When I import the surfaces the stern and mid section import fine, but the end control points at the bow (where it was split) are not well defined as shown in the attached screenshot.
Do any of you know how to rectify this problem?
I have also attached the iges file. Thanks in advance for your help!
Dave
Old 05-10-2006, 02:00 AM
bhnautika bhnautika is offline
Rep: 547 Posts: 541
Dave downloaded file and imported it into MS and I got this.
Old 05-11-2006, 07:29 AM
Rep: 11 Posts: 128
Hi folks,
Hmm... thank you very much for trying it... I exported an iges file from maxsurf and then re-imported it and it appeared to work. Does anyone have any ideas why?
Are there any suggestions as to what I could do to skip the middle step?
-Dave
Old 05-11-2006, 08:04 AM
Rep: 206 Posts: 391
Dave
What version of Maxsurf are you using to import the file? More recent versions may do a better job, particularly if trimming is involved.
Andrew
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
iges trimmed surface problem in maxsurf hasicktear Software 16 02-13-2006 11:25 AM
Importing into Freeship LP Software 4 10-14-2005 03:56 PM
Iges to Maxurf troubles. pro_user Software 4 06-01-2005 03:03 AM
Importing and exporting between Rhino 3.0 and Autocad 2004 Coen Software 4 03-01-2005 09:27 AM
Free IGES models. Dim Education 0 07-01-2003 12:15 PM
