Old 05-13-2007, 09:37 AM
Troutcatcher Troutcatcher is offline
Rep: 12 Posts: 76
Importing hulls to Prosurf
Greg Carlsonīs free hull design software contains numbers of preentered hulls including a Whitehall for example. The files have the extension .hul
I want to import some of these .hul files to Profsurf.
Does anyone know how this can be done??
Thanks in advance,
Troutcatcher
Old 05-13-2007, 11:38 AM
CGN CGN is offline
Rep: 121 Posts: 547
No direct way, has to be done manually or maybe using a txt file to import the coordinates of the "main sections" (these will be the control vertexes on prosurf)
other way may be to export the hull on 3D from Hulls, as a DXF, and import the hull into prosurf, once there, create a surface with similar number of control points (vertex) and use the DXF points to "snap" the surface control vertex points to it, that should give you a really close surface to the original design.
most of this should be on the manual
cheers
Old 05-13-2007, 11:50 AM
SeaSpark SeaSpark is offline
Rep: 96 Posts: 593
Rhino
I may be wrong but think Hulls does not export 3D dxf
You can use the 25 save demo version of rhino to import the DXF and recreate the surfaces using the "curve from 2 views" command and surface "edge curves"
Export as iges to Prosurf.
Old 05-13-2007, 05:52 PM
Rep: 12 Posts: 76
Thanks
Thank you for your quick reply. I will experiment with the methods you suggested.
All the best,
Troutcatcher
Old 05-13-2007, 08:55 PM
Bruce Taylor Bruce Taylor is offline
Rep: 35 Posts: 34
FREE!ship 2.6 reads Carlson's .hul files and can export IGES.
Download here:
http://sourceforge.net/project/showf...roup_id=140466
Old 05-13-2007, 09:07 PM
Rep: 96 Posts: 593
Freeship
Thanks Bruce, the Freeship option is the best by far.
Old 05-14-2007, 11:23 AM
CGN CGN is offline
Rep: 121 Posts: 547
When you open the "hulls" file in prosurf (as a DXF) it will show the model in 3D, all the views that are supposed to be projected are shown in prosurf and i think in rhino too, as a 3D geometry, this way you can use it as a reference to "build" a surface around the wireframe. I'll use prosurf first to generate the 3D model surface, and then use rhino to finish the modeling.
I haven't used freeship to open a "hulls" file but knowing the great job that martjin did, I'm sure that should be the easiest way to go.
Unfolding & Importing from SW to TC erinh Software 3 04-05-2007 11:18 AM
Importing tables of offsets from Excel to Freeship Troutcatcher Software 2 12-19-2006 12:20 PM
importing iges to Maxsurf DaveB Software 3 05-11-2006 09:04 AM
Importing into Freeship LP Software 4 10-14-2005 04:56 PM
Importing and exporting between Rhino 3.0 and Autocad 2004 Coen Software 4 03-01-2005 10:27 AM
