Old 03-01-2005, 03:51 AM
Coen Coen is offline
Rep: 39 Posts: 30
Importing and exporting between Rhino 3.0 and Autocad 2004
Hi you all,
As a 3rd year student naval architecture in The Netherlands, we have to design an Offshore Support Vessel. The prelimenary linesplan had to be handdrawn, which we finished last week.
I started putting transverse sections into rhino, so we have a simple 3d model. We want to use this 3d model for our General Arrangment plan. My plan was making sections of the waterlines where the decks start, so we now how much floor space we have.
In Rhino, this works perfectly. Every waterline we reproduce looks perfect and is exactly the same as the model. When we export it to autocad it all goes wrong. According to autocad, the waterlines aren't symmetrical no more, the waterlines are a lot more narrow than in rhino. Conclusion: something went wrong.
When I do the same but use dxf files instead of dwg's, it is even worse. So I presumed it had something to do with the type of file. Yesterday evening I wanted to try it with .Iges or .Igs files, but my autocad version doesn't import this type of files.
Does anybody have a solution for my problem?
Thank you for your reply!
Coen Meerbach
3rd yr Student Naval Architecture
Professional University Inholland Delft.
Old 03-01-2005, 04:02 AM
dougfrolich dougfrolich is offline
Rep: 140 Posts: 560
Try importing using splines instead of polylines. It should be an option when you export dwg from rhino, I think that might work.
Old 03-01-2005, 05:50 AM
wbouwmans wbouwmans is offline
Rep: 10 Posts: 10
Hello collegue,
I've just tried the suggestion mentioned above for an old design i had laying around. If you use splines it works.
:!: The road to succes is always under construction :!:
Old 03-01-2005, 08:03 AM
Rep: 39 Posts: 30
Yes, but when you use splines this will be quite inaccurate.
I found out that you can differ the number of points rhino exports with in the last screen before exporting. YOu can make the seg and chord lengths smaller and bigger which will add or remove control points in your polyline (in autocad).
Thanks for the reply anyway.
Old 03-01-2005, 10:27 AM
Rep: 10 Posts: 10
Well I don't seen any difference between export of plines and splines. i've exported the both, and put them over each other in acad 2005. They're both perfect. And you are only going to use it for a general plan anyway. In the third GO office (next to froude hok) my general plan still hangs on the wall. those waterlines are exported from maxsurf, using splines. Is that not accurate enough?
greetings,
wouter
