| Import Linesplan DXF to FREESHIP? Hi everybody, i have a linesplan in DXF format. I have to scale it and want to import FREESHIP. How can i make? How can i import offset or linesplan (in DXF format) to FREESHIP? Thanks a lot |
| I don't think you can, but why would you want to anyways? You should read the manual that should have come with it, but I think you can import a text file that has the curves in it.
__________________ Imagination is more important than knowledge. -Einstein |
| Import and scale? i have a linesplan and i have to scale it's Lbp 50 m to 65 m. How can i scale? I think may be FREESHIP can... Do you offer me any software for scale ship? (Lbp, B,D,T and CB) |
| You can scale a dxf in BricsCad or IntelliCad. www.bricscad.com |
| This software scale offset? This software create a offset table? It's a marine software? |
| No, it's a general cad program. It simply scales the lines. To scale an offset table you could use Excel or OpenOffice maybe? |
| It's not help to me Only ship or marine software can scale(Lbp, B, D and CB) |
| I am sorry, I didn't quite understand what you want :-) Lbp, length between perpendiculars? CB, center of buyoance? |
| [quote=internetturk]i have a linesplan and i have to scale it's Lbp 50 m to 65 m. ..QUOTE] If the linesplan is a dxf ddrawin, I would just scale it to be 65m :-) |
| You can but.. you can but how to redraw frame sections? How to calculate CB or LCB... but Marine software make it. |
| Yes, I agree. FreeShip or RhinoMarine for example. IN the old days a boatbuilder would scale the the frame spacing also, so the frames remained the same. LCB should be in the same relative position if you only scale the length. There are so many possiblities, you could import a lines plan into freeship or rhino and the model a new hull close to the existing lines, then scale an make new sections. |
| Ok how to import linesplan FREESHIP? How can make existing hull in FREESHIP? |
| This is from the FreeShip user manual, page 17! 3.5.4 Surface. Import a textfile containing a number of 3D curves. This option can best be used when the offsets of a round bottomed hull need to be imported. These curves may have any number of points which may differ from curve to curve. Usually the curves run from the bottom of the hull upwards, however longitudinal curves are allowed too, just as long as all the curves have the same orientation and run in the same direction. It is important that the curves are not crossing each other. The user will be prompted how many points in longitudinal direction (number of columns) and in vertical direction (number of rows) the imported hull must have. Then the program fits a B-Spline surface through these points such that the new surface interpolates these points. The first line of the file must either be a 0 (zero) or a 1. A zero indicates that all coordinates are in meters while a one indicates that the coordinates are in feet. Each curve is defined by a sequence of X,Y and Z coordinates separated by at least 1 space. The end of a curve is indicated by an empty line after the last coordinate. The last line in the file should be 'EOF'. The following is an example of a file containing 3 stations. |
| And the example! 0 10.62990 0.00000 1.75504 10.62990 0.15186 1.87085 10.62990 0.36387 2.07768 10.62990 0.51880 2.25144 10.62990 0.71454 2.51209 10.62990 0.91032 2.83897 10.62990 1.03680 3.13278 10.62990 1.10212 3.33143 10.62990 1.18380 3.65010 11.81100 0.00000 2.26416 11.81100 0.20519 2.48343 11.81100 0.36424 2.71927 11.81100 0.55190 3.09169 11.81100 0.68655 3.41447 11.81100 0.80491 3.75381 12.99210 0.00000 3.01751 12.99210 0.09559 3.19544 12.99210 0.18538 3.43133 12.99210 0.25068 3.62583 12.99210 0.33232 3.86172 EOF |
| Here's another possibility, convert the body plan to jpg or bmp and load it as a background. Then make a hull. |
| Rhino DXF output | catsketcher | Software | 17 | 01-13-2012 01:01 PM |
| Photo to DXF conversion | farjoe | Software | 8 | 04-08-2005 09:20 AM |
| Flying Dutchman Linesplan | quicksail | Sailboats | 1 | 03-24-2005 06:59 PM |
| How to import solids created in AutoCAD to Rhino? | Tobias | Software | 5 | 08-05-2004 12:29 PM |
| PolyCAD DXF out problem | Guest | Software | 1 | 11-27-2003 04:53 AM |
