  #46
Old 03-29-2007, 04:05 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Just my suggestion.
It depends on the profile view.
very often you have an angle between the back of the keel, where the rudder hangs, and the bottom of the canoe body. That's where it's logical to split the two surfaces. You can join them as a polysurface for easier hydrostatics.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
  #47
Old 03-30-2007, 07:44 AM
ivansalasj ivansalasj is offline
Rep: 10 Posts: 63
Hello,
What I can do is post the Rhino file if you are interested Craig by the end of today since I am modelling at the moment, my aim is to have a smooth surface so I can calculate basic hydrostatics, does that work?
Regards Ivan
  #48
Old 03-30-2007, 07:48 AM
Raggi_Thor's Avatar
Yes, one smooth closed surface will work for hydrostatics, but it's often easier to get the shape you want with two or three surfaces and then join them to a polysurface. Fore example you can model the topsides and the keel with some space between and use Blend to create the third surface. There are many ways :-)
www.MBOATS.no
  #49
Old 03-30-2007, 07:52 AM
Crag Cay Crag Cay is offline
Rep: 572 Posts: 635
The other two views to compliment the body plan you posted above would be great. I can then see how easy all this would have been in Maxsurf and let you have some pointers if possible.
  #50
Old 03-30-2007, 08:04 AM
Rep: 10 Posts: 63
Ok I have a rough view of the profile, but its with a surface, I am back in the office and dont have rhino see what you think, and good advice i will try to use the two surfaces for modelling but I have not done any fairing with the lines they are still defined by decens of points.
  #51
Old 03-30-2007, 08:07 AM
Rep: 10 Posts: 63
Here is the profile rendered its the only thing i can post for the next hour...
  #52
Old 04-02-2007, 03:03 AM
Rep: 10 Posts: 63
Hello,
No thoughts on the profile I attached last week? I will attach a 3d view of the rendered hull by the end of today...
Regards Ivan.
  #53
Old 04-02-2007, 08:56 AM
smartbight smartbight is online now
Naval Architect
Rep: 50 Posts: 99
Looks to me like you could do all that in Freeship/Delftship much easier than in Rhino? They have similar boats in the
database. I use Rhino (great software!) above deck.
KB from lines plan ivansalasj Boat Design 3 03-25-2005 06:34 AM
How to import solids created in AutoCAD to Rhino? Tobias Software 5 08-05-2004 11:29 AM
Lines plan from Rhino AndyRed3D Software 14 08-04-2004 11:05 AM
lines plan development fede Boat Design 4 11-23-2003 07:30 PM
lines plan for cal 2-29 trimhorn Boat Design 0 06-20-2002 02:45 PM
