Old 09-03-2003, 04:28 AM
matled matled is offline
Rep: 10 Posts: 3
IGES file to .OFF file
I'm developing an optimization procedure for the design of an IMS boat. I'm using a program that automatically generates and exports IGES files, but I need a .OFF file on order to use it on the IMS VPP. IS there o software that makes the conversion from IGES to .OFF?
Thanks.
Old 10-30-2003, 02:35 PM
guest12020101217 guest12020101217 is offline
Rep: 10 Posts: 40
IGES to .OFF
Just read this old post
Here a few ideas
HydroLink - Part of the Maxsurf range will take in a iges and output a .off
Have done it myself due in my degree into the WinDesign VPP software.
Look under the software session of www.boatdesign.net/net
Other companies with software that might do it are
AeroHydro Inc
AutoShip
Wolfson Unit at Southampton University in the UK
Hope this helps
Colin
Old 10-31-2003, 03:34 AM
Sounds like an interesting project. What are you planning to optimise and how are you planning to do it?
Old 11-01-2003, 07:31 AM
Rep: 10 Posts: 40
Project was for my final year in uni
Design was for a IRM 45ft using the IC 45 as a base boat.
Basicly l model the IC as best l could and used it to race my design models.
Used to VPP outputs, Time of 1nm, Time of 1nm windward/leeward course etc etc, and then applied the IRM rating to see which models were faster or slower then the IC 45.
Had pages and pages of spreadsheets showing performace changes to changes of rig, beam, length, sail area change.
Wanted to get a design that would beat the IC45 at least 60% of the time over a range of condition.
Was designing for inshore condition mostly. Very hard to get a fast off AND inshore boat. Anyway, 70% of IRM/IRC racing is inshore really.
Also was using the Delft series for resistance and LCB, Cp optimising.
Didn't really work that well and had to rush the work in the end.
Now work designing RIBs. Seem to be better at it then designing race boats!
Thanks for your intreset
Colin
Iges to Maxurf troubles. pro_user Software 4 06-01-2005 03:03 AM
Single Hull IGES File for RoRo/Ro Pax hardy Software 5 10-11-2004 04:32 AM
series 60 lines / CAD file DaveB Boat Design 0 08-09-2004 02:12 PM
Problems with creating an offset file with autoship koen Software 2 08-06-2004 03:37 PM
Canoe - 3D Model File Needed nkeith Software 3 10-31-2003 09:35 PM
