Old 03-01-2010, 01:49 AM
Lukas Lukas is offline
Rep: 10 Posts: 10
IGES to delftshipt to Michlet...
Hi,
When I import an IGES into Delftship, using VRML format, it imports my shape in meters instead of millimeters. I then scale it down in all dimensions by a 1/1000 factor and I get the right draft (which makes me think that it should be OK).
I then export as Michlet, entering all the parameters for skin frictin, wave resistance, hull separation distance as this is a catamaran and then:
- either does Michelt bugs
- either it opens but there is no shape in the differents view windows
In all cases, the export has not worked.
Can anyone tell me where I am wrong?
Could I send the file to someone that knows how to convert thses with the different parameters to get a hand?
Thanks in advance, Lukas
Old 03-01-2010, 05:33 AM
Previous Member
Rep: 0 Posts: 0
You can attach the iges file to a post if it is not a secret. Otherwise email me direct with it. rickwill@bigpond.net.au
You need to advise the hull spacing if you have a single hull. Also what is your maximum speed of interest.
Rick W
How to convert GF to IGES sys Software 1 01-17-2008 10:09 AM
IGES Importer For AutoCAD snowbird97 Marketplace 0 09-08-2007 11:24 AM
iges to freeship pavel915 Software 8 08-10-2007 09:14 AM
iges to GHS file pavel915 Software 0 08-01-2007 08:11 AM
DELFTship 3.1 IGES Import sorbit Software 2 03-27-2007 03:20 AM
