Old 02-22-2005, 10:21 AM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
I appreciate how surfaces are trimmed, but my point still stands. If the surface is imported as a trimmed surface it should be treated as such.
Tim B.
Old 02-22-2005, 07:56 PM
Rep: 206 Posts: 391
Originally Posted by Tim B
Then by definition, Andrew, that is incorrect.
A properly imported trimmed surface should be the same shape as the origenal trimmed surface.
Tim B.
Tim
The imported data consists of two pieces, IGES entity 128 which contains the surface data and IGES entity 144 which contains the trimming data. Maxsurf reads the IGES 128 entities correctly, but does not read the IGES 144 entities. Clear now?
Andrew
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 02-23-2005, 04:42 AM
Rep: 1729 Posts: 2,462
Andrew
We look foreward to Maxsurf being able to read IGES files in their entirety.
IGES users will then find Maxsurf much easier to interface with since our trimmed surfaces will remain just that without having to repeat the work.
This is why the Rhino addins like Rhino marine are so much easier to work with at present.
When will you implement this ?
Mike Johns.
Old 02-23-2005, 06:58 AM
nemo nemo is offline
Naval Architect
Rep: 137 Posts: 132
I realized today that GHS files are the same format as Autoship's Autohydro ones. I think it's a great thing, even if many of you could dislike Autohydro.
IMHO, it's very useful when you have to manage a large number of tanks, I'm thinking about ships, because you can import the hull from Rhino, and then fit all the tanks directly in Autohydro, or you could even write a macro for excel and insert the tanks in terms of number.
