Hydrostatic Stiffness Matrix in ANSYS AQWA
Discussion in 'Software' started by mekchu, Sep 12, 2013.
  1. mekchu
    mekchu Junior Member
    HI all,
    I was wondering about hydrostatic stiffness matrix in ANSYS AQWA. According to hydrostatic stiffness matrix formulation described in Section 3.1.3 of AQWA Line Manual, the pitch and roll restoring components (RXX, RYY) is not affected by center of gravity (CG) location. However, I tested simply cylinder model considering different CG position. I realized that there is different value for the pitch and roll restoring components. What's wrong?
    Please give me some advise for this situation.
    Thanks.
  2. jehardiman
    Likes: 1,171, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Cylinder on end or on edge? Cylinders are not good hydrostatic test cases, they have a lot of interesting singularities.
  3. mekchu
    Hi Jehardiman,
    Thank you for your responses.
    Actually, I also tested semi-submersible platform model which seem to be complex geometry. I realized that the hydrostatic stiffness matrix depends on CG location. That's why I used simply cylinder model to test my analysis.
    Can you give me some advises?
    Cheers.
  4. UTKARSH RAMAYAN
    UTKARSH RAMAYAN Junior Member
  5. CWTeebs
    Likes: 15, Points: 0, Legacy Rep: 171
    CWTeebs AnomalyGenerator
    Did you add an internal lid?
  6. mekchu
    Hi CWTeebs,
    I did not use internal lid option.
    Cheers
  7. CWTeebs
    Add one, it'll stop those fictitious waves inside the spar.
