| hydrostatic in rhino 3 I designed a hull in rhino 3.The WL is 9.8 m,When I check hydrostatic it gives me WL is 13.7 m !!!and I think also the rest of the calculations are wrong. I deleted the model several times and restarted again But the same result !! If you have any idea what I'm doing wrong Regards |
| Hi Ahmed, its always handy if you include the file so we can see what your are doing. I assume you are using the hydrostatics command under analyse. I tried it out, and it works fine for me. Perhaps you can check your waterline - by default its the cPlane - if your boat is below the cPlane, then its going to give a waterline length closer to the maximum hull length (and a displacement equal to the entire volume of the hull... Hope this helps Grant |
| I will try to attach the file tonight.But I'm sure the WL is the 0 in the cplan! Thanks for help |
| hydrostatic in rhino 3 This is the file which is done with rhino 3. It's just an inial hull to check the hydrostatic. I would apreciate your comments ! Regards |
| After an Xmas dinner, all my blood is in my stomach, and so I can not say exactly why, but if you set the option 'symetric' after you start the hydrostatic command, to Yes, then you boat is 9.8meters... just as we assumed it was. Have a nice holiday period, Grant |
| Rise the body 0.001 m and hydrostatics will work. If the body has several corners exactly at origin, rhino's hyrdostatics can do errors. Here are my results after 1 mm rising: Volume Displacement = 5.15971 Center of Buoyancy = 4.7028, -6.88549e-016, -0.210555 Wetted Surface Area = 18.6501 Waterline Length = 9.79552 Maximum Waterline Beam = 2.2674 Water Plane Area = 15.2934 Center of Floatation = 4.36588, -4.84571e-016,0 Sounds reasonable. RhinoMarine found it similar. ps. your model had two stems, deleted one. Terho Last edited by terhohalme : 12-26-2007 at 03:15 PM. Reason: Forgot stems. |
| Thanks alot !!!! It works great and I got the same result. another question please Is there large deviation sometimes between the hydrostatic in rhino& rhinomarine regards |
| Rhino's hydrostatics is only for quick checking and can give unexpected results. Rhinomarine modules are for real yacht design work. Look at: http://www.rhinomarine3d.com/ |
| 2D Rhino to Autocad export and rhino sectioning | fede | Software | 13 | 10-18-2009 03:55 AM |
| Need some help on RHINO | Barbaros | Boat Design | 6 | 08-07-2007 12:19 PM |
| Hydrostatic assessment packages for long keel vessels | Sotondesign | Stability | 2 | 10-19-2006 07:13 PM |
| "Freeship" hydrostatic stats analysis of three ships | jedclampit | Software | 17 | 02-23-2006 09:28 PM |
| Rhino help | Vibtor | Software | 2 | 04-15-2005 06:34 PM |
