Old 11-04-2009, 09:06 AM
petlily petlily is offline
Rep: 10 Posts: 29
Hydrostatic Properties at certain heel angle in Autohydro
Hi,
Is there anyone knows how to produce a table of hydrostatic Properties at a designated heel angle in Autohydro?
Been looking high and low in the manual but there isn't any macro that enable this to be done
Appreciate very much for any help towards solving this problem.
Old 11-21-2009, 04:21 AM
babri babri is offline
Rep: 10 Posts: 2
Hi petlily,
just don't define drafts and don't use /km parameter for ghs command. for example following commands will force to zero heel:
ghs dr 1.1,1.15,...,2.8
ghs /km
So only use ghs command without any paramater. the result is a one-row hydrostatic table for defined draft, trim and heel angle.
for multiple drafts write a macro and use a loop to calculate hydrostatic properties for different drafts. Then edit the results in word software to join the one-row tables to a perfect hydrostatic table.
hope this help
Old 11-23-2009, 08:33 AM
Rep: 10 Posts: 29
Hi babri,
Thank you for your suggestion. Tried using the ghs but no matter how I tried, the heel is always forced to zero.
The only solution I figured out, is to use hs instead of ghs, such as this;
heel 5
hs 1, 1.2, 1.4, ...3
I still get the hydrostatic table at heel 5 deg albeit certain parameters have been omitted like KMt, KMl, etc. Note that the inclusion of new parameters such as BMt, BML, which is independent of centre of gravity.
got problem to define angle in autohydro.. cess odean Software 2 08-04-2009 03:59 AM
Relationship between angle of attack of keel and heel angle stelios Sailboats 9 05-29-2006 02:14 PM
Advice Needed In Calculation Angle Of Heel sujith Boat Design 2 11-18-2005 02:54 AM
Static heel Angle Aproximations budner1 Boat Design 2 05-15-2005 11:09 AM
Optimum heel angle Blether Sailboats 9 06-09-2004 06:46 AM
