Old 03-24-2010, 06:36 AM
Kreso's Avatar
Kreso Kreso is offline
Rep: 10 Posts: 47
Hydromax Model Flooding
Hello,
I've made model in maxsurf and all surfaces are joined correctly. In hydromax rendering of model shows flooding even though all surfaces are correctly joined. After Equilibrium calculation Sectional Area Curve shows graph without any unexpected spikes or hollows, results in large angle analysis shows expected results.
It seems to me that flooding is not sign of mistake ?!?!
Please give me response if you have similar experience..
Thanks
Old 03-29-2010, 10:22 AM
viet_ntu viet_ntu is offline
Rep: 13 Posts: 5
check the zero points and other settings that are required to do the calculations., each calculations has some different requirements, also check the units are same as u modeled in maxsurf,
if the problem continues, it would be better to show some picture too,
here is many experienced user in hydromax.. I think u will get a solution .
thanks
Old 03-29-2010, 10:56 AM
Kreso's Avatar
Rep: 10 Posts: 47
That 'flooding' isn't sign of mistake, checked with Maxsurf..
Thanx
Australian National Standard for Buoyancy and Stability after Flooding mflapan Stability 27 09-16-2010 01:34 AM
Flooding Hull grp.boat Boat Design 1 02-02-2007 05:53 PM
Borg Warner Velvet Drive Model 72c Current Model DAVID HOSEGOOD Diesel Engines 1 12-27-2006 12:30 AM
Carburator flooding on Evinrude 15hp odysseus Outboards 4 08-06-2006 08:04 AM
Help me! (Re: Hydromax) kreg Software 6 06-11-2004 04:55 AM
