Old 03-20-2010, 03:48 PM
Don Case Don Case is offline
Rep: 10 Posts: 22
Hullform question
Hi all
I'm fairly new to hullform and boat design. I'm trying to find what the Hullform equivilant to CLR or CLP is. I'm thinking that it is the X-center of area below waterline. Am I even close?
Thanks
Don
Old 03-20-2010, 05:50 PM
LyndonJ LyndonJ is offline
Rep: 233 Posts: 302
I'm not sure where you are in relation to your experience with this software but if you are using the free version you are better off learning freeship these days. Hullform has fallen by the wayside a bit and you will find it frustrating capmpared to freeship.
Old 03-20-2010, 06:52 PM
Rep: 10 Posts: 22
I was using Freeship but I couldn't heel the boat(if I remember right),has that changed?
Don
Old 03-21-2010, 05:42 AM
baeckmo baeckmo is offline
Hydrodynamics
Rep: 962 Posts: 631
I still use one of the first Hullform versions for quick first estimates of hull geometry and evaluation. Personally, I feel comfortable with the command structure of the Hullform for the first "brainstorming sessions" before final design.
When you have a hull and balance it in the "statics" mode, you will get a presentation of all relevant parameters, but I do not recognize the constants you mention. The annotation may have changed in later versions, but the "help" chapter should get you on track.
Old 03-21-2010, 07:40 AM
Rep: 10 Posts: 22
It is the Center of Lateral Resistance that I am trying to determine. It's also called the Center of Lateral Plane. I can find no reference to it in the "Help".
Thanks
Don
Old 03-21-2010, 08:16 AM
Hydrodynamics
Rep: 962 Posts: 631
Hah, the lateral area and its center are not available in my version (#6), so sorry, can't help you there.
Old 04-03-2010, 05:36 PM
Oldsalt31 Oldsalt31 is offline
Rep: 10 Posts: 3
Hi Don, I may be late with this reply but ..... I assume that the title X centre of area below waterline is what you are looking for. This dimension is from point of entry of course. I am a self taught user of 9P and still learning but together with Terho Halme's fine spreadsheet there is a wealth of information to be had .
My project is an 8 mtr. cat. All the best, John
HullForm Starfish Boat Design 2 06-02-2008 03:00 PM
Delftship to Hullform Don Case Sailboats 7 11-20-2007 06:50 PM
Someone knows about where to get a HullForm 7 Çemberci Software 3 05-03-2007 12:44 PM
need series 64 hullform. pls help....... gmjoarder Boat Design 1 04-18-2005 07:35 AM
How do I get offsets into Hullform 8P demo? Archive Software 1 06-12-2001 03:44 AM
