| Hull Modeling With Rhinoceros |
| T-spllaines is quite new. The method called "rapid hull modelling" is not new for V4, it worked OK in V3 and probably V2(?) also. But I agree, Rhino is getting better and better, with even more plugins and addons :-) |
| its updated. |
| The tutorial? That's great. I have used it for some training classes and it's very good. |
| Has anyone found that V4(beta) runs slower (at least for the interface) than V3 on existing systems? I am using a system with 2.6GHz P4, 2GB RAM and Radeon 9550 GFX Card and Win XP SP1. Might there be a linux version of V4, it would be easier for me (and many others I suspect, and it would save me supporting Microshaft) Cheers, Tim B.
| You never stop do you? :-) Muy guess is that even if McNeel doesn't say so, they are experimenting with linux, and will have a version for it if the numbers make sense. |
| hi all i have just meet rhinoceros .Has anybody had e-book or tutorial about rhinoceros v3. or v4 THANKS
__________________ Naval Arch. & Marina Eng. |
| Search this site for Rhino Tutorial. Also see the Rhino home page and Tutorials. I like one from Rhinocentre in Netherlands. |
| Thanks for your contribution
| This is the document from www.rhinocentre.nl that I mentioned: http://www.rhinocentre.nl/pdf_bestan...Rhinoceros.pdf I like it because it starts with a quite practical description of nurbs curves. |
| hi everybody i have a question about rhino and 3ds max.i agree rhino is the best modeller for hull modelling.But what about the rendering.which is the best.Can rhino do perfect render as 3ds max.Has rhino very various render tools as 3ds max.İf the answer is yes how can i find rhino render tutorials.Thank you. |
| Try Flamingo. Download from www.mcneel.com or http://www.flamingo3d.com/ You also have some free rendereres with interface for Rhino or import possibilities, but they are more work to get used to, in my opinion (and I am not nreutral). Maybe also try these: http://www.maxwellrender.com/ http://blog.rhino3d.com/2008/08/braz...o-beta-18.html http://www.rhino3d.com/resources/dis...e=&listing=870 (more suggestion here) |
| Rhino hull modelling hi everbody i want to create hull surface model with 3 pcs. sections , main deck and CL section profile in rhino.But i have a problem about surface modelling as you see on the attachment.I want to modelling hull via only one command with using sweep rail 2 command and with these curves (sections ,cl section and deck) But rhino can't do this surface via one command (sweep rail 2 ) And i have to do this model with two surfaces and two different command.Isocurves of the surfaces dont connect each other.You see two surfaces as red and green on the attachment.i have created red surface with sweep rail 2 and i have created green surface with loft.Red surface has created as surface and green surface has created as polysurface.you know these surfaces are not proper.Question is how can i create a good hull surface via these curves.Do my curves not enough or cant i use commands as proper.What is the problem. Thank you Best Regards |
| try the command loft,It's much more finer than sweep2rail in round hull modeling. Better with the loft command to use the section currves only,because they start and end on CL & Deck line,No need to add them to make it easier for the program. when you pick the curves try to be organized,pick them in a correct sequence,one after the other & all you pick near the top end or the bottom end or you'll get a bad surface. regards ahmed wahab |
| mr. ahmed very thanks for your answer.at that condition i need more sections curves for modelling hull.3 pcs. not enough.i'll try this. regards |
| Best Marine Design Software for Hull Modeling? (2007) | Admin | Software | 91 | 04-08-2008 04:12 AM |
| Rhinoceros 4 RELEASE CANIDATE 1 announced today020207 | Antisthenes | Software | 0 | 02-02-2007 08:52 PM |
| Best Marine Design Software for Hull Modeling? (2006) | Admin | Software | 95 | 01-01-2007 02:59 AM |
| Rhino/Solidworks hull modeling | mattbyrne | Software | 1 | 01-11-2005 10:46 PM |
| Hydrostatics in Rhinoceros | Software | 10 | 06-24-2002 02:27 AM | |
