Old 10-21-2004, 07:07 PM
longngone longngone is offline
Rep: 10 Posts: 8
hull designers using DWG?
I've been doing all my drawings in AutoCAD 2002. It has come to the point where I need to start doing some calculations. Unfortunately I'm not a math wiz, and would prefer some Computer Assisted help with calculations. Is there any software that interfaces with AutoCAD that could help me, or anyone who loves running formulas? Any help would be great!
Old 10-22-2004, 02:52 AM
Mario Mario is offline
Registered
Rep: 10 Posts: 44
As I know there is no a special ACAD application for hydrostatics calculating only.
You can do it by conversioning your DWG file into DXF file and then put it in one of the special softwares. It would be a quite complicated for some of them. I contribute it in one example of conversion ACAD->Maxsurf.
I made a program named Kus-SHDM (www.kus.hr) that runs inside ACAD for designing a sailing hull on a unique method. In my program there is a hydrostatics calculation, not only upright. Because of testing the hydrostatics results I use MAXSURF.
Converion from ACAD to Maxsurf is in way making a file that consists points of the hull and geting it to Maxsurf¨s Prefit program that make a surface of your hull. After that you can use other Maxsurf`s program.
Mario
Old 10-24-2004, 11:39 AM
cgorton cgorton is offline
Rep: 10 Posts: 50
You could also download the evaluation version of Rhino (free for 25 saves) and the evaluation of the Rhino Marine plug-in (free for 2 weeks). Rhino can open DWG/DXF/IGS, etc.
This is assumng the calculations you are speaking of are marine related (hydrostatics, stability, etc.)
Hull speed Mike D Boat Design 33 02-27-2011 01:20 AM
How about boat design definitions JonathanCole Boat Design 55 01-24-2010 04:48 PM
Luhrs T-29 (1995) diesel inboard converted to outboard Iya Boat Design 13 03-07-2007 06:48 PM
Jet Drive Jet Drives 15 12-18-2006 09:51 AM
Stepped Hulls Ryon Macey Powerboats 53 08-01-2004 10:44 AM
