Old 10-05-2004, 10:08 AM
ageny ageny is offline
Rep: 10 Posts: 5
how to transfer the shipconstructor surface to maxsurf
i have made a surface in shipconstructor, but i don't know how to transfer the surface to the maxsurf? could somebody help? thanks a lot!
Old 10-05-2004, 04:10 PM
CGN CGN is offline
Rep: 121 Posts: 547
I'm guessing that you create the surface in shipcam and then send it to shipconstructor, There is no way to do what you want without losing accuracy of such surface, usually the surfaces that you use in shipconstructor are useless, becouse they are just meshes and not a nurb surfaces wich you may be able to reuse in other softwares, the only way is to aproximate such surface in any other software like maxsurf, but still is not like "saving and open it on maxsurf" so you have to find the best way to aproximate such surface.
there is some ways to recreate such surface with good tolerances but it will not be 100% the same.
Old 10-07-2004, 10:42 AM
Rep: 10 Posts: 5
i wanna know what is the easiest way to transfer the surface. because i had suffer from doing the job, my procedure was to save the surface section as dxf file ,then open it in maxsurf as markers, after that i fitt a surface to the markers. but i don't think it is the right way to do this, right?
Old 10-07-2004, 10:58 AM
Rep: 66 Posts: 640
Don't know what your trying to do, but might be an idea to try it the other way around! Design the boat in Maxsurf and transfer it to whatever program you want, for whatever reason.
You'll always have the problem of the one program not corresponding with the other, unless they are specially designed that way.
Dutch Peter
Old 10-07-2004, 06:56 PM
Rep: 206 Posts: 391
Maxsurf is for designing hulls, Shipconstructor is for building them. The ShipConstructor hull module can import IGES NURBS surfaces from Maxsurf, but does not export them.
As Dutch Peter said, design your hull in Maxsurf then export to ShipConstructor.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 10-27-2004, 10:39 AM
Rep: 10 Posts: 5
thanks,i have got a demo of it, and find it easy to learn.
I Want to get help in Maxsurf. zzt9876 Software 4 02-01-2005 08:48 PM
Q. Lines-planes form AutoCAD to Maxsurf ? cmcguinness Software 0 12-06-2004 05:02 PM
AC yacht modelling accurately on Maxsurf?? ac4ever70 Software 2 11-24-2003 09:48 AM
