Old 07-21-2011, 02:20 AM
waldemar123 waldemar123 is offline
Rep: 10 Posts: 6
How to smooth the body lines ine the Maxsurf 13?
Hello, I doing body plan from a few plan view in rhino 4.0, then i want to export model 3D to maxsurf 13 (ti maxsurf 13 is possible export model from rhino 4.0) and smooth the lines. But I don't know how to do it.
Can You help me?
best regards,
Old 07-21-2011, 10:42 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 263
Read Manual First. It tells everything. But if u trimmed any surface in Rhino, after import to maxsurf it will be untrimmed. so avoid trimming in Rhino or make that surface in maxsurf.
DAre To DreAm
Old 07-22-2011, 01:31 AM
Rep: 10 Posts: 6
Thamks a lot, I found i manual description "smooth"
Best regards
Old 07-22-2011, 03:20 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
For smoothing the lines you have to take some stations, waterlines and buttocks there and by control point manipulation you have to make those lines fair. Whenever you drag any point the contours will be updated automatically.
Md. Al-Amin Pavel
http://www.paveldesign.tk
"A question that sometimes drives me hazy, am i or are the others crazy?"
Albert Einstein
Old 07-25-2011, 08:08 PM
juangadea juangadea is offline
Engineering & Design
Rep: 10 Posts: 5
I suggest ging the other way around. First design the hull in Maxsurf, it´s much easier to fair than on Rhino. Then import the hull into Rhino and continue with more detailed deck or appendages surfaces.
Old 07-27-2011, 11:30 AM
Rep: 10 Posts: 6
Thanks, but in rhino I feel much better than Maxsurf
Rhino X shape smooth modelling Guinther Software 6 06-07-2011 07:43 AM
How to Maxsurf 3dm from ACAD lines plan? soundsail88 Software 7 11-04-2009 04:33 PM
How smooth is smooth enough? RHough Boat Design 8 10-31-2006 07:54 PM
Modelling in Maxsurf with existing lines plan squivo Software 1 03-07-2006 03:35 AM
Q. Lines-planes form AutoCAD to Maxsurf ? cmcguinness Software 0 12-06-2004 04:02 PM
