| how to rhino model import ansys Hello I need help about importing ansys..... |
| Rhino to Ansys I noticed that you posted this a couple of weeks ago, any luck? If not here are some points I have found useful: (This is a very tricky opertation, you will probably spend longer importing than actually runing an FE analysis with it!) Also I have only imported into ANSYS 12.0 Classic (Academic edition) I have found that importing the .3dm file as an IGES 144 file works the best. Have a play around with the importing tolerances, make sure they are consistant between the IGES (which is unitless) and into ANSYS (which has user defined units). From memory 0.001 worked for my work. This will differ for liscence and process power. Then view the imported geometry as lines and show line numbers, this is so you can see if there are any double lines (lines on lines). If there are go back to Rhino and delete the double lines, then do it all again. What type of analysis are going to run? |
| ı try to analyse @ fluent ![]() |
| aah CFD, the dark art have you sorted your import problem? im not familiar with the fluent environment, we use CFX for fluid problems at uni and that is not until this upcoming semester (final year!) |
| Exporting rhino model into delftship? | Tcubed | Software | 6 | 09-23-2009 02:05 PM |
| Import Lines Plan to Rhino | ivansalasj | Software | 52 | 04-02-2007 08:56 AM |
| Assigning Thickness to Rhino Model | S Hondros | Software | 7 | 07-23-2006 04:12 AM |
| 3D Rhino model and 2D drawings | signum | Software | 2 | 08-19-2005 06:35 AM |
| How to import solids created in AutoCAD to Rhino? | Tobias | Software | 5 | 08-05-2004 11:29 AM |
