Old 09-27-2010, 08:48 PM
tuanshipland's Avatar
tuanshipland tuanshipland is offline
Yacht Designer
Rep: 10 Posts: 18
How to model exactly 3D wing (NACA series) for hydrofoil in CATIA?
Hi all,
You can share with me how we could design 3D wing such as NACA 2410 for hydrofoil in CATIA software? Because I want to calculate CFD in fluent and stress and strain in ANSYS 11.0.
In my way, I define many sections of wing, then I use multi-sections solid in Part Design in CATIA to model 3D wing. How about your experience?
Thanks for your share!
Tuan Shipland
tuanshipland@gmail.com
TUANSHIPLAND
Sailing Our Dream
http://tuanshipland.com
Old 10-13-2010, 12:30 AM
Yacht Designer
Rep: 10 Posts: 18
How to import file.dat to catia for deign NACA wing?
Hi all,
Do you know how to import file.dat to catia?
Thanks for sharing your knowledge!
TuanShipland
TUANSHIPLAND
Sailing Our Dream
Old 10-17-2010, 08:12 AM
sail sail is offline
Rep: 10 Posts: 19
am designing a 7 m cruising beach cat and its folding system. It has a central longitudinal beam supporting the cross beams.(It is easier for a trimaran since the main hull acts as the central longitudinal beam).
I would like to explore the possibility of hydrofoils placed at the bow and stern of the longitudinal beam?
Since a cruising cat should not list at more than 10°, I was thinking to "hang down" the dagger board, foil cases and rudder on the same beam.
The foils will not be to lift the cat off the water but at speed >10 knots to stabilize it, reduce pitching, decrease wetted area and hopefully increase speed.
Except the rudder , any foil appendix (including the foil at the base of the dagger board) could be lifted in its case (at low speed) and neatly tucked under the longitudinal beam between the 2 hulls. Will the increased wetted surface and drag of the foils will be compensated by a profitable lift gain? I m not sure.
Is the idea possible? The space between the folded hulls is about 800 mm at the center and 1500 mm front and rear. Displacement of the cat will be around 700 Kg, sail area around 30-34 m2.
I would appreciate your help.
Old 10-19-2010, 08:29 PM
Yacht Designer
Rep: 10 Posts: 18
You can test your model in water tank or you also test CFD of your model. I cannot know what software you have designed your model and what standard you design the foils (NACA?), so I just give you some references. For CFD, you can use Fluent, Ansys CFX and so on.
I hope I give you useful comments!
Nice ^^
Tuan Shipland
TUANSHIPLAND
Sailing Our Dream
Old 10-19-2010, 09:24 PM
Rep: 10 Posts: 19
Nice ^^
Tuan Shipland
Thanks for your post Tuan Shipland.
The information I gathered is that hydrofoils are designed for a narrow speed range, are useless at low speed, very expensive to design if you hire a specialist (160 US$/ hour..no fixed global estimate).
Yes I will use NACA 600 series for rudder and dagger board.I also have as a reference, plans of trimarans I bought 2 years ago: Ian Farrier's folding F-22 and Paolo Bissol demountable Tritium 720.
As a conclusion, I will wake up from my "hydrofoil fantasy" and use as everybody else does, dagger boards and keels (build 2 prototypes).
Old 11-03-2010, 12:52 AM
Yacht Designer
Rep: 10 Posts: 18
Can you share what NACA you exactly use? I think you can use 2 prototypes for testing in watertank.
I really like F-22 model. You can see more on http://www.f-boat.com/pages/trimarans/F-22.html
Can you share images of your model in this topic? (dagger board and rudder)
Keep in touch!
TUANSHIPLAND
Sailing Our Dream
Old 11-07-2010, 03:24 AM
Rep: 10 Posts: 19
NACA foils
Tuanshipland
Here are the NACA foils and 3D rendering:
How to model exactly 3D wing (NACA series) for hydrofoil in CATIA?-6.99-m-cat-profile.jpg
Old 11-07-2010, 08:44 PM
Yacht Designer
Rep: 10 Posts: 18
Tuanshipland
My computer can not read you image in .doc, it need Quick Time to decompressor, so you can send me file .pdf or file .jpg. In addition, you have coordinate NACA 600 in file.txt or file.DAT ? Otherwise, I google the NACA 600 but I dont see NACA 600 series. Hic ^^ ...I will try to simulate NACA wing in fluent for you! Then I upload it for you.
Keep in touch!!
TuanShipland
TUANSHIPLAND
Sailing Our Dream
Anyone using CATIA V5 ? Software 27 01-24-2011 11:59 PM
need 10 meter sail general arrangement delft series model 27 karabacak Sailboats 8 12-25-2009 02:07 AM
CATIA for boat design signum Software 19 02-23-2007 10:20 AM
CATIA in South Africa CDC_Catia Software 0 01-08-2007 06:07 AM
Catia and design Artur Software 2 09-02-2003 11:48 AM
