Old 11-01-2009, 01:28 PM
soundsail88 soundsail88 is offline
Rep: 10 Posts: 3
How to Maxsurf 3dm from ACAD lines plan?
I have the lines for a ship in autocad and would like to create a maxsurf 3dm. What is the most efficient way of going about this?
I have read in maxsurf's help files that an image can be used and lines be "traced," as well as importing a dxf file and tracing over markers. The first method seems inefficient and for the second, I cannot figure out how to convert the 2d dxf into a 3d dxf as the maxsurf help file suggests. Thus, when I import the dxf into maxsurf, my lines plan shows up in the plan view and as straight lines in other views.
I'm trying to learn maxsurf and don't have a great handle on it yet. If I were doing this in rhino, I would create a grid with my bodyplan in autocad and import into rhino. I would then rotate the body plan and distribute stations onto the grid. Is there any similar method for maxsurf?
Thanks!
PS: Title should read "How To: ..."
Old 11-01-2009, 05:00 PM
bhnautika bhnautika is offline
Rep: 499 Posts: 489
Soundsail88 the method you described for rhino is what you have to do before you import into maxsurf to get 3d from 2d. You have to create a 3d line drawing from 2d parts then export that out as dxf (lines and arc). You can then import into maxsurf as dxf background lines or dxf markers.
Old 11-01-2009, 11:12 PM
maodou maodou is offline
Rep: 10 Posts: 25
This can do by autocad,I can do it for you if you like
Old 11-02-2009, 03:49 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 252
To make 3d lines from 2d is easier in Rhino .In autocad i personally feel it difficult. You will have to vary z keeping x,y constant.
In rhino Just import your bodyplan and then offset the stations according to your station spacing. if u cant understand just check the attachment in this post
modeling hull of tanker ship in Rhinoceros
i tried with 3D but i dont know why maxsurf can only generate trimesh surface from it . i also could not make hull from the 3d lines perfectly.
Hope someone can also guide me regarding this post
Old 11-04-2009, 03:02 AM
Rep: 10 Posts: 3
The big hang-up for me in Rhino seems to be the bow/stern bulbs and how to convince Rhino to loft in two 'branches'.
However, I'm trying to figure out maxsurf principally and the help files/tutorials fall pitifully short of answering anything but the most basic questions. I can't even figure out how to delete stations...
Old 11-04-2009, 03:45 PM
Rep: 499 Posts: 489
Soundsail88 to delete a section just go to data>grid spacing>sections, then high light the one you want to delete, then delete. You can add in the same way.
Old 11-04-2009, 05:32 PM
JLIMA's Avatar
JLIMA JLIMA is offline
crazed throttleman
Rep: 130 Posts: 101
Actually I too , am trying to learn Maxsurf but it is kicking my ass....horribly...
Answering AAII based on reserve steam
Old 11-04-2009, 05:33 PM
JLIMA's Avatar
crazed throttleman
Rep: 130 Posts: 101
So...anything anyone could say here would be great....
About ship lines plan nguyenthanhnghi Boat Design 4 10-29-2009 12:18 PM
Lines Plan builtinpieces Boat Design 3 10-28-2009 01:14 PM
Modelling in Maxsurf with existing lines plan squivo Software 1 03-07-2006 04:35 AM
KB from lines plan ivansalasj Boat Design 3 03-25-2005 07:34 AM
lines plan development fede Boat Design 4 11-23-2003 08:30 PM
