| How to make file "loadcase.hml" directly! I want to modify or create the file directly without running maxsurf! and I want to make that file that maxsurf can understand! Some one can help me! |
| First off, why? Second, if you want that then you will have to find the specifications on the maxsurf file format. Do you know anything about programming? If not, just load maxsurf and make a file. |
| Now, I'm on project that get data from Maxsurf, analysis and then make the "load case" file for Maxsurf solve again. I can't modify it from Maxsurf because if I do that , maybe haven't got this question!! I think 10 years propraming just enough. Thanks. What I want are found the structure of that file and made it. If you have exp. about that please tell me! Last edited by mymind04 : 01-05-2010 at 01:24 AM. Reason: forget st. |
| You dont have to use a hml file. Just set up your weight schedule in Excel and then copy and paste it into the load case Window in Hydromax. Copy and paste an existing schedule from Hydromax to Excel to get an idea of the format. Remeber you have to add the rows into the load case window before pasting into them. |
| A good idea, but let me try! Thanks! |
| something wrong? when I copy data in environtment of Maxsurf and save as .hml. Load case in Maxsurf almost data mess up, and have stranger data! |
| Not sure I follow you. 1. Create a load case in Hydromax 2. Add some sample loads 3. Copy and paste that table to Excel 4. Modify the table as required in Excel 5. Add rows in Hydromax to match the number of rows in the Excel table 6. Copy and paste the Excel data back into Hydromax. |
| Thanks formsys! That way is OK, but I mean that I have a program out side Maxsurf. I use that to analys my work, after this program solve, I will use output data from it's and then make a file loadcase and then Maxsurf done! I hope you know what I mean, this situation I can not open Excel and pass to Loadcase Maxsurf interface because I need make lot of loadcase for my work ( I take lot of time). I want make loadcase files by code!!! |
| 'Sailing'?? Directly to Windward | brian eiland | Boat Design | 183 | 11-30-2011 09:22 PM |
| Sailing Directly Upwind | ancient kayaker | Sailboats | 83 | 02-20-2010 02:39 PM |
| Making a female mould directly?? | Raggi_Thor | Fiberglass and Composite Boat Building | 11 | 09-27-2009 09:10 AM |
| CNC cutting file....need to make one. | MikeJohns | Software | 6 | 02-08-2006 09:40 AM |
| IGES file to .OFF file | matled | Software | 3 | 11-01-2003 07:31 AM |
