| How is Intact Stability claculation Done?? Can any one advice me on how can the Instact Stabiliity calculation be done and what are cross curves of stability?? |
| Depending of where you are bhabanism, Basic Ship Theory by Rawson & Tupper may be easier to find. Both will provide the basics. |
Cross curves are for vessels of variable displacement such as cargo ships, the stab. curves are calculated for different displacements. {edited to add clarity} Each of a number of curves curve represent a certain heel angle the horizontal axes is displacement and the vertical axis is righting arm gz, alternatively it can be the righting moment. What sort of vessel are you analyzing?
| Have a look at: http://web.nps.navy.mil/~me/tsse/NavArchWeb/
__________________ Guillermo Gefaell Gestenaval S.L., Naval Architecture & Marine Engineering Moon Yacht Design |
| Stability calculations. For starters, let's not make this more cmplicated than it is. Start with the Displacement to length formula, or D/L This formula is; D/L= D/LWL/100 x cubed D/L= Displacement divided by Watreline length divided by 100, the result is cubed Also Calculated the Aove water/below water area ratio |
| I have all what u want This site will give a full Marine engineering lectures, which will give u a very good idea of almost every thing http://www.usna.edu/NAOE/courses/en200/ download the pdf chapters & enjoy yourself also i have attached a small word file of my own work to give u a quick idea about stability. Have a nice time ![]()
__________________ Alexandria Universty Faculty of Engineering Department of Marine Engineering & Naval Arcitecture |
| basic software for intact/damage stability | John Toner | Software | 13 | 10-20-2007 04:55 AM |
| Intact Stability | Sea Dog | Boat Design | 7 | 02-21-2006 01:50 PM |
| Directional Stability | Wardi | Sailboats | 9 | 06-01-2005 01:10 AM |
| stability | Guest | Boat Design | 2 | 12-30-2003 02:31 PM |
| Dynamic Stability | aidel_amrd | Boat Design | 0 | 04-27-2002 03:48 AM |
