Old 07-19-2007, 09:16 AM
Ahmed Wahab Ahmed Wahab is offline
Rep: 15 Posts: 26
how to insert point to a chine
Dear all
If somebody can help
How to insert a point to an existing chinein specific x,y,z without splitting the chine.
Because with splitting the chine the geometry of the hull.
Good Day
Ahmed
Old 07-19-2007, 05:28 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
I am guessing you are using a computer program?
What kind of software is it?
In Rhino for example, if you use a nurbs curve (or surface) of third degreee you may need three points in line to force the curve into that line.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 07-20-2007, 06:41 AM
Rep: 15 Posts: 26
I use freeship.when I try to extrude the cabin and superstructure after in a specific stations.But splitting the chine doesn't bring the new point to the specific station without modifying the geometry of the faired hull.
I'm thinking May be there is a way to insert the new points to deck chine in specific stations
Old 07-20-2007, 07:41 AM
Raggi_Thor's Avatar
OK, we'll have to ask some of the Freeship experts...
www.MBOATS.no
Old 07-22-2007, 08:18 AM
Rep: 15 Posts: 26
thanks Raggi for your reply,I wish to get rhino but I live in Egypt and wht is known here only autocad.
Good day
Ahmed
Old 07-22-2007, 02:46 PM
Steve Baer Steve Baer is offline
Rhino Developer
Rep: 64 Posts: 90
Hi Ahmed,
You can always download and use the evaluation version of Rhino at:
http://www.rhino3d.com/eval.htm
Rhino was designed to work as a good companion to AutoCAD and you should be able to share AutoCAD DWG files back and forth with Rhino. If you want to buy Rhino, just let me know.
Thanks,
-Steve
Can someone please point me in the right direction? eitanwaks Open Discussion: All Things Boats & Boating 7 05-17-2006 08:07 AM
Square chine/round chine messabout Boat Design 6 03-15-2006 09:49 PM
mold insert to deal with negative return corners?? Pavook Fiberglass and Composite Boat Building 4 11-28-2005 12:10 PM
Heavy sailboats : Can they point ? xarax Sailboats 100 06-24-2005 09:36 PM
how do i insert images? joelhickey Open Discussion: All Things Boats & Boating 1 06-08-2004 04:28 AM
