Old 09-10-2006, 04:20 PM
Grant Nelson Grant Nelson is offline
Rep: 159 Posts: 203
How to fillet corner of two intersecting pieces
Hi,
I am practicing with Rhino, creating a solid seat. I am having a problem creating a fillet that goes around the corner formed by two intersecting pieces of trim. Hopefully there is a picture below. I have also attached the picture and the Rhino file.
You will see that I have created a surface around the corner, but I can not get Rhino to trim off the tips. I also could not get the FilletSuf command to do anything. I would like to keep the pieces separate, since I want the design to represent the actual pieces used.
Can anyone help me figure out hot to make this work?
Thanks, Grant
How to fillet corner of two intersecting pieces-fillet-intersection-two-objects.jpg
File Type: 3dm Fillet intersection of two wood pieces.3dm (119.6 KB, 77 views)
Old 09-13-2006, 03:39 AM
Rep: 159 Posts: 203
An answer
OK, I figured out one way (but I would still like to know why trim does not work in my first case, and how I would fillet the results if it did...)
Here is how it did work:
[list][*]I created the two pieces of wood, with them overlapping at the 90 degree corner[*]I trimmed off a round corner, which trimmed both of the still overlapping pieces.[*]I filled the hole in each piece opened by the trim by extending the curve at the top (or bottom) of the opening down (up) to the other curve to create a surface (cap did not work)[*]I joined the two surfaces of each piece to create a closed solid[*]I used filletedge and selected the three edges on one piece I wanted to fillet[*]I did this to both piece of wood[*]I then created a cutting plane at 45 degrees and trimmed off the ends of the peices of wood to match each other
And it was done
How to fillet corner of two intersecting pieces-trim-fillet-intersecting-pieces-works.jpg
mold fillet material Dark57 Fiberglass and Composite Boat Building 9 09-11-2006 01:27 PM
How to Fillet Corners? S Hondros Boat Design 8 08-29-2006 03:28 AM
Maxsurf Q - Bonding Intersecting surfaces ? cmcguinness Software 1 02-17-2005 12:07 AM
Keel design and corner hull roberto.bertoli Boat Design 1 10-26-2004 10:28 PM
Alternative fillet materials? Ward Boatbuilding 16 09-03-2004 09:40 PM
