Old 12-30-2009, 07:54 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 263
how to do the job for a fair and best bulbous bow shape?
hello guys,
i am in a problem which is very common if any one want to do 3d hull shape with bulbous bow from an existing lines plan. i am trying it do in rhino. but i get it hard to produce a fair shape. many people say use loft , or use networksurf . or etc.. but dont see who did it by himself rather than giving theory.
i will be happy to get some help if any one show me a way to make the good shape from this lines by doing it as an example
Thanks much..
still learning
Old 12-31-2009, 08:42 AM
bhnautika bhnautika is offline
Rep: 547 Posts: 541
Zeroname using just sections for this surface won’t give you enough information, there is too many gaps to fill in around the bow area for where the edge of the surface is. Sometimes a mix of waterlines and sections gives you a closer match. Also dividing the surface into different parts rather than one piece can make it easier. Because your line drawing of the sections is made up of a lot of control points you need to use the “rebuild with” function in the loft options to reduce the number of points to just enough to get your shape. I used some of these methods to do a quick down and dirty shot at it.
Old 12-31-2009, 12:10 PM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 263
thanks .. and nice to see ..
then u did following by rebuild command to reduce control point and then ...
if u kindly share the sequence [ if u dont mind !] will be a good support. as i am learning ...
if u can kindly pm me the 3dm , so that i can analyze and modify it more ...
thanks
Old 12-31-2009, 08:24 PM
Rep: 547 Posts: 541
Zeroname in the loft > rebuild, you can put in the number of control points for the surface. Play around with the number using the preview button until you get the surface accuracy that you want. The most important thing with loft is always pick the lines from the same end (say the sheer line end in this case). Here is my file, which is not perfect as it has gaps between surfaces. The trouble with creating surfaces from lines using loft is you have trouble with the edges of the surface between the sections, as they end up being the side edge when it should have been an end edge.
Bulbous Bow Cb nmfb105 Boat Design 2 09-16-2009 09:09 AM
I'm conviced an eskimo style upswept split bow acts like a bulbous bow, but Squidly-Diddly Boat Design 4 08-23-2009 06:08 PM
Bulbous bow Hotel Lima Boat Design 1 09-09-2007 05:23 PM
NAVSEA Job Fair dereksireci Services & Employment 0 06-22-2006 10:53 AM
bulbous bow costing tjrrong Boat Design 1 09-08-2004 07:15 AM
