Old 06-14-2007, 07:02 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
How do I determine the proper pitch in FreeShip?
I have a design that looks like it is "bow high, stern low" and I want to adjust it so it will be displayed as if the boat is floating naturally in the water. Does FreeShip have a feature that re-orients the boat so that it is shown in the proper balance, just like it would be if it were in the water?
If not, how can I determine this?
Kenneth Grome
Old 06-14-2007, 12:19 PM
CGN CGN is offline
Rep: 121 Posts: 547
If you want to see your boat "floating", you can use Bio Design with freeship
http://www.geocities.com/dumchikov/bio_design/
model your hull on freeship and export to bio, read the instructions on the bio site, is a good "fast" way to see your boat floating
what you need to know is the weight of your boat and the location of your centre of gravity.
Get a copy of "how to design a boat" by john teale, good reading and with the information on how to find your center of gravity.
Also this may help you
http://www.hawaii-marine.com/ftp/WM-e.zip
Old 06-14-2007, 12:28 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
FreeShip's "transform" menu has an option, "rotate", which you might try applying to the entire hull. But if you want to know how it'll really float, not just how it looks in sketches, you'll have to follow CGN's advice and calculate the actual weight and CG.
Old 06-14-2007, 08:58 PM
Rep: 287 Posts: 719
Before I posted this thread I tried rotating the design in FreeShip but as Marshmat says, this doesn't tell me how the boat will actually float in the water.
I downloaded the BioDesign software as recommended by CGN, and the .wmv instructional video, too. I haven't tried the software yet but the video makes it look quick and easy to use for my purposes, so I think it will do exactly what I need.
Thanks to everyone for the help!
Kenneth Grome
How do you Determine Composite Thickness? solarboater Fiberglass and Composite Boat Building 4 03-31-2011 10:09 AM
Proper anchoring mariner 40 Open Discussion: All Things Boats & Boating 8 02-22-2006 05:56 PM
How do you determine motor size lee@simmtechs.c Propulsion 6 11-22-2005 03:48 PM
Proper drain hardware? Mark V Boatbuilding 3 01-09-2005 04:46 AM
A proper model... Sean Herron Boat Design 0 10-17-2004 03:36 PM
