Old 01-19-2011, 10:03 PM
adt2 adt2 is offline
Rep: 36 Posts: 83
How do I deal with this transition? (Rhino)
I'm a new-ish Rhino user, and I'm having a little trouble with a hull side-to-transom detail (see the attached image). I figured out how to use Trim to trim the funky triangle of hull side that extends onto the swim platform area, and I'm assuming I can use the same function to trim the curved transom flush with the hull side.
What I can't figure out is how to deal with the missing triangle at the aft edge of the hull side, below the swim platform. Is there a way to extend the hull side surface to the lower transom edge? Or should I add a point along the sheer, way aft of the transom, to extend the hull side surface and then trim it at both the upper and lower transoms?
Thanks in advance for any assistance you can offer.
http://picasaweb.google.com/adt7771/...eat=directlink
Last edited by adt2 : 01-19-2011 at 10:05 PM. Reason: Attached image didn't work; changed to link.
Old 01-20-2011, 05:28 AM
ACuttle's Avatar
ACuttle ACuttle is offline
Marine Design Engineer
Rep: 40 Posts: 85
Before you trim the surface out above the swim platform, select the sloping vertical edge of your side surface and use the 'extend surface' command (I don't recall the menu of the top of my head but it's just off one of the primary tool bars). Extend it out by 500mm or so then trim it back onto the swim-platform and the transom.
You can extend trimmed surfaces but it doesn't do such a nice job, your better off to extend the surface untrimmed and then trim back wherever needed.
Just shout if that doesn't makesense.
Edit:
I've just checked, it's on the 'surface tools' toolbar - fairly predictably.
-Drew
Old 01-20-2011, 09:26 AM
Rep: 36 Posts: 83
That did it - thanks.
I think what threw me off on that command was the Command Line prompt ("Extension factor <1.00>:"). WTF is that? Why not have that prompt read "Extension length <1.00">:" or something similar?
Anyhow, thanks for the help.
Old 01-20-2011, 10:21 AM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
The "extension factor" input of the "extendsrf" command is one of the more mysterious elements of Rhino. It isn't a simple distance and it isn't a simple proportion of the surface size. It also isn't linear. An extension factor of 10 doesn't necessarially result in an extension 10 times longer than an extension factor of 1.
I generally start with 1 and if the extension is the wrong length by a considerable amount I undo and try with a different extension factor.
Wood-Fiberglass Transition gtplante Boat Design 3 07-11-2009 11:03 PM
Deep V deadrise transition Ben Nelson Boat Design 0 01-30-2009 08:45 AM
Transition sails from Richard Dryden Pericles Sailboats 5 03-18-2008 04:57 AM
Calc. of transition in Boundry Layer??? or thickness'! GuestR01312011 Boat Design 2 11-27-2007 08:46 AM
Steel/ Aluminum Transition Stock timgoz Metal Boat Building 4 02-13-2007 03:34 PM
