Old 04-10-2007, 02:41 AM
Previous Member
Rep: 0 Posts: 0
Holding hands:))
Guys, gals.
you can probably see by my posts that I,m a hands on man, BUT I do struggle with CAD
Can anyone PLEASE spare the time to hold my hand with Maxsurf(yes I,ve read and reread the manual)n I have literally done 200 hrs on this and got nowhere at all
thanks Stu
Old 04-10-2007, 08:37 AM
Bergalia's Avatar
Bergalia Bergalia is offline
Rep: 254 Posts: 2,517
holding hands
You and me both, Jack
Old 04-10-2007, 10:10 AM
Crag Cay Crag Cay is offline
Rep: 547 Posts: 629
It's best to ask questions about specifics and even upload the file with which you are having problems. Then I'm sure you will get the help you need.
Many of us don't have the time to simply 'hold hands' but are willing to help!
Old 04-11-2007, 06:17 PM
bhnautika bhnautika is offline
Rep: 499 Posts: 489
Stu I have a bit of experience with maxsurf and other cad, I also have a little time on my hands at the moment. I might be able to help out.
Old 04-11-2007, 09:17 PM
Previous Member
Rep: 0 Posts: 0
thanks people, Take delftship(free) I can not bring up the pink comb that smoothes lines, hightlight the line to purple, click curve, the feather does not appear? any idea, I will try post the file
Old 04-11-2007, 09:19 PM
Previous Member
Rep: 0 Posts: 0
file
see the flats, I follow tute but can not bring up that pink feathered comb
Old 04-11-2007, 11:27 PM
raw raw is offline
Rep: 59 Posts: 133
I just took a look at the dxf. Whilst I am not conversant in delftship, it looks at if your surface is defined as having straight sections in the longitudinal direction (hence the flats). In this case, there is no curvature, and thus you will not see a porcupine graph.
In maxsurf/rhino, this is fixed by looking at the longitudinal "degree" of the surface properties. Degree 1 is linear. Anything above will give curve. Degree 3 cubic splines are pretty common and usefull for most applications.
Again, I'm not familar with delftship per say, but this is where I'd be looking.
brett
Old 04-11-2007, 11:36 PM
Previous Member
Rep: 0 Posts: 0
G,day,
i found the porcupine as you put it, but its so hairy like all over the page, the flats seemed there by default, no matter where you drag they are present
I sent you a pm, ?
two days ago
Old 04-11-2007, 11:41 PM
raw raw is offline
Rep: 59 Posts: 133
I replied to you by pm 10/4 on tuesday. Did you get it?
I'll have to have a play with delfthip a little later to see if I figure it out. I'm not the best person on that program unfortunately.
Old 04-12-2007, 02:31 AM
Rep: 499 Posts: 489
Stu the model in dxf seems to be made up of panels, which are going to be impossible to fair. Is this the sort of thing you are after, its three surfaces in Maxsurf.
Old 04-12-2007, 03:02 AM
Previous Member
Rep: 0 Posts: 0
yes it is a two chine yacht based on Robert Clark Design, I jave the original dwgs from 1970,s, my mate sailed this boat around the Horn, very stiff she was
i figured I must fair each line separately as it is they all show at once, I just gte so frustrated but I,ll keep on til I get it I do have maxsurf but cant seem to exprt it there Thank you v much
Old 04-12-2007, 03:09 AM
Previous Member
Rep: 0 Posts: 0
0oh I see, DUH I have made all the body sections, creases!! duh!!
Old 04-12-2007, 06:06 PM
Previous Member
Rep: 0 Posts: 0
ok, I,m sorter sorting it, another question,
If I open a default file, and I want more depth to the hull, like more rocker , then the default comes up with a very high wooded topsides, in other words all is out of reasonable proportion. So if I type in Depth, say 800mm, the freeboard is nearly 3m, If I enter from (new) depth 500mm, then all is in proprtion, my question, is there a way of holding these acceptable proportions but increasing the hull depth? thank you, another day at the coal face, but beats plating a steel boat I guess
Old 04-12-2007, 08:13 PM
Rep: 499 Posts: 489
Stu there is a quick way round your problem, create your default boat with a 500mm depth, then go to the project menu – project settings- main dimensions, then change the draft to 800mm.
Old 04-12-2007, 08:23 PM
Previous Member
Rep: 0 Posts: 0
actually I stumbled there by mistake, but it wont alter the wl measurement of base, so I will have neg values from base in offsets, er um that is when I learn how to find the offsets, thank you)
Holding tank construction Gene H Boat Design 3 03-02-2007 05:22 PM
Copper holding tanks and photos of 1946 Elco joshbygosh Marketplace 1 01-21-2007 08:29 PM
Tahoe Q-3 2001 Lights and Fish Holding Wiring Fes Boat Design 0 07-20-2006 08:47 PM
My hands get cold Thunderhead19 Software 14 04-27-2005 04:38 PM
Polyethylene holding tank Terry Materials 2 03-16-2004 11:19 AM
