| High Performance Boat design software Can someone suggest a good software package that I could use to design performance hulls with and maybe generate actual computer generated images of the boat. Thank You. Kurt |
| check the posts at software forum there istons of references and comments on software used to design boats good luck |
| <Admin note: moved to the software forum> Welcome to the forum Kurt. As is said above, take a look at the threads in this forum. Download the demos for the software listed in this thread: Best Marine Design Software for Hull Design? (2001-2005) Most have free demos available (with limitations such as not allowing you to save or export). Even the ones that are beyond your budget will give you an idea of what is available and where you want to go in the future and it would be worth your time to download and spend a little time with each one before making a decision. Paul also provided a nice step-by-step introductory tutorial for using Rhino in this thread http://forums.boatdesign.net/showthr...&threadid=1401 which you might find interesting. |
| boat design software | ciao8167 | Boat Design | 1 | 06-29-2005 12:01 AM |
| Why Use Design Software | Wynand N | Boat Design | 17 | 12-02-2004 03:08 PM |
| Hull Design software | Tom.B | Software | 23 | 08-20-2004 03:41 AM |
| Rudder design for solar boat | lost at sea | Boat Design | 9 | 01-26-2004 12:39 PM |
| Boat Design Software | rstedman | Software | 1 | 10-29-2003 02:21 AM |
