Old 06-07-2004, 01:10 PM
kreg kreg is offline
Rep: 10 Posts: 16
Help me! (Re: Hydromax)
Excuse me for my bad English but i'm Italian. I need help in order to learn hydromax. I must analyze the stability of a boat for my final studies in architecture.
where I can find tutorials about hydromax.
thanks.
Old 06-08-2004, 02:50 AM
Rep: 206 Posts: 391
Kreg
Please log on to the Maxsurf Academic website (http://msacademic.formsys.com) and go to the tutorials page. I have added the Hydromax training documentation, split up into three separate pdf files. Hope this helps.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 06-09-2004, 01:42 AM
Rep: 10 Posts: 16
ok...
thanks......
i can ask you if you have also the training of hullspeed?
Old 06-09-2004, 02:08 AM
Rep: 206 Posts: 391
Hullspeed Tutorial
I've posted a brief Hullspeed training document, it is fairly simple, but Hullspeed is a pretty simple program.
Andrew Mason
Formsys
Maxsurf Academic
Old 06-09-2004, 02:12 AM
Rep: 10 Posts: 16
good, i can only say you thanks
Old 06-11-2004, 04:47 AM
fede fede is offline
Rep: 34 Posts: 281
Hi , I just received my upgrade copy to MS 10 it seems it's still not able to correctly import trimmed surfaces coming from rhino...am I correct? I might be making some mistakes in the process of saving and importing.
Hei Kreg, contact me, I'm a yacht design student from Italy too and would like to get in touch with other people with the same interest.
Old 06-11-2004, 04:55 AM
Rep: 206 Posts: 391
Fede
For the moment you have to retrim in Maxsurf. The reason is that we do dynamic trimming between surfaces, whereas the IGES format simply records the trimming for each surface, it has no idea that the trimming originated because some other surface was intersecting it. As a result it is difficult for us to reconstruct the trimming from an IGES file.
We are working on being able to trim to arbitrary curves in a surface rather than purely surface/surface intersections, this loses the dynamic nature of the trimming but will allow correct trimmed surface importation via IGES.
regards
Andrew
Andrew Mason
Formsys
Maxsurf Academic
Hydrostatics differences between rhino and Hydromax nemo Software 18 02-23-2005 06:58 AM
Hydromax - moment wenc Boat Design 6 02-09-2005 11:52 AM
Hydromax and yacht stability tomcat Boat Design 3 01-24-2005 05:46 AM
fluid density in Hydromax DaveB Software 1 07-15-2004 02:48 AM
