Old 03-04-2009, 01:10 PM
arturoike arturoike is offline
help for maxsurf
Hi, I'm new in this forum. I need help to manipulate a set of markers imported from a dxf. I don't find out how to associate to surfaces. Thank
Old 03-05-2009, 06:01 PM
yachty4000 yachty4000 is offline
Rep: 36 Posts: 36
I am sure Andrew will give you a detailed answer, But you may need to be clearer on the question. If your talking about importing surfaces created on other programs then you need an upto date version.
If your talking about generating surfaces from point clusters read the prefit guide and it explains the limitation of this function very well.
Old 04-01-2009, 04:32 AM
formsys formsys is offline
formsys
Rep: 33 Posts: 72
If you are using the latest v13 or v14 release, you can graphically select the markers and then use the properties sheet to set the surface they are associated with. You can also view the table of Markers in the markers window and change the value in the Surface column
Old 04-02-2009, 10:40 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 252
please read the manual carefully.. you can get ur answer in details their.. i hope so
Maxsurf please HELP!! lazeyjack Software 14 01-25-2012 01:32 AM
help with maxsurf rob_fox Software 4 05-19-2008 10:55 PM
help with maxsurf snow 57 Software 7 01-10-2007 11:20 PM
Maxsurf Q (AutoCad -to-Maxsurf) cmcguinness Software 1 12-01-2004 05:00 PM
ask for help in Maxsurf zzt9876 Software 4 05-19-2004 05:31 AM
