| help with lines plan how do I create a 3D model in Rhino? I have lines plan in dwg....... i need a tutorial or procedure |
| here's a link to a tutorial. there are several methods that work involving loft thru curves or sweep rails, depending on the type of hull. http://pkboatplans.com/files/Rhino_40sqm_Hull.pdf |
| The proceedure in the document Tim provided the link works well to provide a "fair" hull shape. But it may not necessarially exactly match a set of lines with more curves than used to develop the shape. One proceedure which should match closely a set of lines for a simple hull shape is to use the sheer, center profile/buttock, the transom outline, and the sections from the lines. Then use the "sweep2" command with the sheer and center profile/buttock as the rails. Alternately the "networksrf" command can be used but the shape will probably be slightly different. Try both. Also with "networksrf" may be possible to add some waterlines to the curve network. Experiment. |
| thanks |
| lines plan | jollyricard | Software | 6 | 07-16-2010 01:21 PM |
| IMOCA 60 lines plan | Chris Cooper | Sailboats | 6 | 12-31-2009 12:26 AM |
| Lines Plan | builtinpieces | Boat Design | 3 | 10-28-2009 12:14 PM |
| KB from lines plan | ivansalasj | Boat Design | 3 | 03-25-2005 06:34 AM |
| lines plan development | fede | Boat Design | 4 | 11-23-2003 07:30 PM |
