Old 11-15-2009, 12:11 AM
Steph357 Steph357 is offline
Rep: 22 Posts: 19
Help for a design in Maxsurf
Hello everyone,
I have been using maxsurf to design hull for a while know, but mostly sailing hull with round shape.
I woul like to design a planning hull thistime for a power boat and I don't really know how to create 90° angle for my shine of the sides of my boat. My control points always give me a smooth shape and I don't know how to remove that.
Thank you
Old 11-17-2009, 01:48 AM
bhnautika bhnautika is offline
Rep: 499 Posts: 489
Steph357 the way I do it is to create two or three linear surfaces and join them then add control points to adjust the shape, here is an example.
Old 11-17-2009, 02:25 AM
Rep: 22 Posts: 19
Ok I see, I tried lot's of things but not this one, thank you very much it will be very helpfull.
Old 11-28-2009, 08:44 PM
yuyewuyuconan yuyewuyuconan is offline
Rep: 10 Posts: 32
use two plane
bond edges
Old 11-28-2009, 08:49 PM
Rep: 10 Posts: 32
or you can add two or more points in that edge
Old 11-29-2009, 09:11 AM
yachty4000 yachty4000 is offline
Rep: 36 Posts: 36
Lots of surfaces can cause you problems in hydromax unless you are careful and if you have limited surface this can sometime not be an option.
You can always change the flexibility of the surface if it is a fully chined shape which is the simplist way! I have done some example designs that merge between the two types of hull shape (e.g. curvey forward section merging into chines and flat planning surfaces aft) the best way of doing this is by having two net points next to each other or group them ontop of each other and it create chines.
I hope it helps
Old 11-29-2009, 10:09 PM
Rep: 22 Posts: 19
I tried your way Yachty, but I found it hard to move the point after to have a very right angle and a fair shape.
Having Two surfaces seems easier to me.
Old 12-01-2009, 06:24 AM
Rep: 10 Posts: 32
Your teacher is maxsurf's help,try this
Old 12-02-2009, 12:41 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 252
problem
hy
please help me to find out a solution for the problem u see in the picture.
what is the co-ordiate problem in the autocad file? each time i import the dxf as markers in maxsurf, it get offset. please help
Thanks
Old 12-02-2009, 04:39 PM
Rep: 499 Posts: 489
Zeroname your 0,0,0 is not on the boat lines move the lines or the zero points to the centreline of the boat and say the fwd perpendicular
maxsurf design shoaib_jaff Software 12 10-14-2009 09:48 AM
using Maxsurf to design a sportfish boat sportfish Boat Design 0 04-04-2009 04:41 AM
maxsurf yacht design rob_fox Powerboats 1 05-09-2008 10:13 AM
Maxsurf Yacht Design rob_fox Boat Design 3 05-07-2008 10:53 AM
design sail and mast in Maxsurf Jiyu Sailboats 2 08-26-2006 11:09 PM
