| help with Carene to Delftship printing Carene will do all the design I need for stitch and glue but the print out is too small..I sent it to delftship which is good but the print/send to plotter icon is grey and inoperative ...any ideas where this old fart is going wrong ??? Nothing in the documentation about printing ....??? |
Can you perform calculations? If not, you'll need to set the main dimensions first. |
| well it is the free version but it says fully functioning ...??? I can zoom in and take the laptop to the workshop and draw out the ply panels but it would be easier to have it on A3 paper ......... |
| Free version is fully functional and should print normally. What is it exactly what you're trying to print? I know that version 3.2 for example will not print a shaded view, only wireframe. You can however save your shaded view as an image and print that. printing a linesplan shouldn't be a problem at all. So, it depends on what you're trying to send to the printer. |
| could not make Delftship print so I downloaded freeship..seemed to be identical ......imported the same file to each ,,both displayed the profiles etc and the plate developent but ony freeship would print it ..??? so i suppose you say problem solved and lesson learned |
| Thee free version of DELFTship does indeed not print plate developments. |
| Printing full sized patterns? | bigkahuna | Software | 28 | 06-18-2011 07:23 PM |
| delftship help!!! | orpheus | Software | 12 | 11-02-2009 03:26 PM |
| Delftship | Manie B | Boat Design | 3 | 05-06-2008 05:51 AM |
| scaling/printing issues | jmedick | Software | 6 | 07-09-2007 11:44 AM |
| Help with a core printing issue...please | DGreenwood | Fiberglass and Composite Boat Building | 0 | 08-12-2004 03:23 PM |
