Old 06-08-2009, 03:36 AM
chaser chaser is offline
Rep: 30 Posts: 17
have troulble with maxsurf
i am learning maxsurf right now
who can help me to check the attached file is correct or not?
i feel have some problem in the model but i cant find out and fix them .
Old 06-09-2009, 08:06 PM
bhnautika bhnautika is offline
Rep: 499 Posts: 489
Chaser in what way do you think it is not right, it seems to all go together. The front of the keel is a little abrupt. I would make the suggestion that you don’t use so many columns and rows as it make fairing surfaces a lot hard than it needs to be, only use the minimum to get the shape you want, having 30 columns and 4 rows for the stern surfaces is excessive when just 2 columns probably would have done.
Old 06-10-2009, 04:28 AM
Rep: 30 Posts: 17
Dear bhnautika:
I would like to sent your my model of hydromax ,but i found it cant be attached in here ,so could you can give me your priviate mail address,Mank thanks!
Old 06-10-2009, 09:38 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 252
u can also upload it here .. so many people can give u good advice
Old 06-10-2009, 08:06 PM
Rep: 499 Posts: 489
Chaser the problem you seem to have in hydromax is that you haven’t put in a draft in maxsurf. Go to menu >Data >frame of reference > set base line then put in a draft and set water line.
Old 06-10-2009, 09:05 PM
Rep: 30 Posts: 17
Dear bhnautika:Thank you for your prompt reply,i have defined draft in maxsurf,in fact i would like you help me to check some definition in hydromax,but the some problem with in the beginning,i cant attacht the hydromax file in attachment.i dont know how to fix this problem,
Old 06-10-2009, 09:57 PM
Rep: 499 Posts: 489
Chaser you need to tell what the problem is! I only have hydromax/s so I may be limited in what I can do.
Old 06-11-2009, 02:14 AM
Rep: 30 Posts: 17
Please see attached file as defect photo,
that is what i met in hydromax,so i suppose have a mistake in hydromax ,but i cant find out what is the problem.
have troulble with maxsurf-defect.jpg  have troulble with maxsurf-defect01.jpg  have troulble with maxsurf-defect02.jpg
Old 06-11-2009, 04:40 AM
gwboats gwboats is offline
Naval Architect
Rep: 68 Posts: 88
Problems with Hydromax
Chaser,
I agree with 'bhnautika' in that your model is too complex in some places.
Try these for starters:
Re-name some of your surfaces with unique names - you have a few with the same name!
If your chine surface (or any other) is flat delete the intermediate rows and define it with top and bottom rows only.
Simplify the stern surface. You don't really need a transom if your side surfaces end OK.
Make sure the major hull surfaces have the same number of columns so you can bond all the adjacent edges.
When you calculate the compartments turn off any surfaces not relevant. I suggest this would include the keel. You can turn them back on when you calculate hydrostatics etc.
Make sure any internal surfaces defining tanks are indicated as such in the surface properties box.
Hope this helps.
Good Luck
Graham Westbrook
Naval Architect
www.westbrookmarine.co.uk
Old 06-11-2009, 05:35 AM
Rep: 30 Posts: 17
Originally Posted by gwboats View Post
Chaser,
Hope this helps.
Good Luck
Graham Westbrook
Naval Architect
Dear gwboats,
because i inport the 3Dmodel from rhino to maxsurf,so some surface have lots of columns and rows.
i supposeed all the surface have been joined,
you know we only can calculate the compartment in hydromax ,so i dont know how to turn off the keel in hydromax,and also tanks were defined in hydromax,so i cant to change anything in maxsurf surface properties box,
Old 06-11-2009, 07:10 PM
Rep: 499 Posts: 489
Chaser I don’t think this is a maxsurf problem but hydromax tank and compartment definition problem as I stated earlier I don’t have hydromaxpro just hydromax/s so I don’t have access to the tank definition sorry I cant help in that . As the model seems to be all right I suggest you start another file adding tanks and compartments one at a time and checking them as you go.
Old 06-12-2009, 04:13 AM
Rep: 30 Posts: 17
bhnautika,i would like to send the hydromax/p to you ,how can i sent the documents to you?,i have turned off the keel in maxsurf,and the above defects is resolved,but the calculation displacment is big difference,so i cant accept it.one more question,please see the attached file,how to solve that problem
Old 06-12-2009, 07:44 PM
Rep: 499 Posts: 489
Chaser I have no experience in those parts of hydromax pro so I don’t think I can help. I would say it could be a problem with “load case” and, or your centre of gravity position.
Old 06-13-2009, 09:09 AM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 252
why u dont contact with formsys.com ? they can give u support .. or u can contact with andrew
Old 06-15-2009, 05:18 AM
Rep: 30 Posts: 17
i have asked formsys,but they cant support me due to i havent the coad of this software.
Maxsurf please HELP!! lazeyjack Software 14 01-25-2012 01:32 AM
Maxsurf Help TimClark Software 5 12-28-2005 12:03 PM
Maxsurf Q (AutoCad -to-Maxsurf) cmcguinness Software 1 12-01-2004 05:00 PM
ask for help in Maxsurf zzt9876 Software 4 05-19-2004 05:31 AM
Maxsurf AE fede Software 10 02-17-2004 08:22 PM
