Old 07-10-2009, 02:32 AM
chaser chaser is offline
Rep: 30 Posts: 17
have a problem of hydromax
when i update the tank and compartment definition,the model is showing as attached photo,i dont know if it will affecta the calculation ?and how to fix this problem,thanks!
have a problem of hydromax-defect-hydromax.jpg  have a problem of hydromax-defect-hydromax-2.jpg  have a problem of hydromax-defect-hydromax-3.jpg
Old 07-18-2009, 10:25 AM
Navdes_E Navdes_E is offline
Rep: 10 Posts: 8
In some case, hydromax can do this. I have designed a passenger ship and i have calculated her tank calibrations. i have seen tank boundaries as yours. as a result this visual problem did not effect my calculations. In my opinionthis problem not desing problem, this is visual problem..
To solve this problem try to increase section numbers, fit tank sections to hull sections and recaltulate all of these. At least, try to add a new light for new direction for lightining...
thanks...
Old 07-18-2009, 11:53 AM
Martijn_vE's Avatar
Martijn_vE Martijn_vE is offline
Marine software developer
Rep: 401 Posts: 251
Hydromax uses crossections of the tanks for the calculations. As far as I can tell the surfaces are simply meshes created by connecting the crossections with triangles. This is in most cases sufficient for rendering purposes, but it's not stable enough for accurate calculations (especially in complex areas like bulbous bow and gondolas etc). In other words, the surfaces are only used for representation purposes. Calculations are done based on the 2D crossections, just like the "normal" hydrostatics.
help about hydromax and workshop zeroname Software 14 12-22-2008 04:08 PM
External Tank definition problem in hydromax ilgazcan Software 4 12-06-2008 10:18 AM
Hydrostatics... with hydromax ivansalasj Software 8 12-14-2004 08:15 PM
Help me! (Re: Hydromax) kreg Software 6 06-11-2004 05:55 AM
