Old 06-06-2011, 06:58 AM
quequen quequen is offline
Rep: 165 Posts: 113
GZ and Righting Moment Spreadsheet
Edit:
.xls file attached on the next thread.
Copy "Cross Curves of Stability" data, obtained from Archimedes MB or (maybe?) Freeship+ and Paste into this .xls
Output: GZ arm curve and Righting Moment curve of your hull, for big heel angles.
You can do small changes to VCG (also called KG) to match the stability curve you want for your vessel. (For big changes, you should modify original hull, displacements and VCG...)
Last edited by quequen : 06-08-2011 at 06:40 PM. Reason: Attached my spreadsheet attempt
Old 06-07-2011, 08:51 PM
Rep: 165 Posts: 113
Attached another one with 3D graphics to show 3D stability mesh. New stability image.
Old 06-08-2011, 07:52 AM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
Kn
You might look at this thread I started way back. It references Freeship, but the info might be useful.
Definition of KN.
LP
God bless the open minded people of the world. LP
Old 06-08-2011, 08:29 AM
Rep: 165 Posts: 113
Thanks LP. So my thougts about KN in Archimedes were right. All this confusing thing about K, N, H, M etc. could be much more clear with a simple graphic beside formulas, just as you did at your post.
Old 06-09-2011, 01:13 AM
Rep: 165 Posts: 113
This is my own image...
Old 06-13-2011, 07:58 AM
Rep: 165 Posts: 113
here's another one, may be better to understand Archimedes KN value
Dr. Gerritsma Righting Moment SuperPiper Sailboats 4 12-31-2010 02:50 AM
Righting Moment Question - amolitor Boat Design 2 01-14-2009 03:04 PM
Righting Moment Stevens47 Stability 2 04-23-2008 09:37 AM
righting moment of a keel rapscallion Stability 4 10-17-2007 09:15 AM
Twin Keel Righting Moment Willallison Sailboats 23 04-04-2006 12:22 AM
