| GZ curve Hi, I have modelled a hull in Maxsurf Demo version, and would require to extract its GZ curve. Unfortunately in the Demo, or the academic version, this is not a feasible option. Is there a FREE software that I can develop the GZ curve after being imported from Maxsurf? Thanks Steve |
| I suppose you could try ArchimedesMB ( http://naval-architecture.co.uk/ ). As with all computerized analysis, the GIGO rule applies (garbage in, garbage out) - the analysis won't mean much until you take the time to go through the program and figure out exactly what each parameter and option means.
| Hi, Thanks for your help. But how can I import the model I have already drawn from Maxsurf? Is there a particular format? Thanks Steve |
| ArchimedesMB can read GHS files, which I believe Maxsurf is capable of generating.
| Hi, Apparently, Maxsurf only reads (imports) a file of GHS format. Thanks Steve |
| If u did it in Maxsurf academic ,,, save it as 3d IGES or rhino 3dm .. now open it in rhino and Save it as GHS format to load in Archimedes.. i assume u have rhino.
__________________ DAre To DreAm |
| Hi all, I did all you said, and I did import it in Archimedes. But I only managed to extract the KN curves not the GZ curve... What am I doing wrong? thanks steve |
| You are practically there. The Kn curves are the stability curves for a VCG height of zero. For each heeling angle phi subtract VCG*sin(phi) to obtain your righting lever GZ, so GZ=KN-VCG*sin(phi) |
| GZ curve in autohydro, | pavel915 | Software | 1 | 10-23-2009 10:59 PM |
| Robinson's Curve | HAO | Propulsion | 0 | 06-07-2009 11:52 PM |
| GZ curve | genesis-uno | Stability | 2 | 06-19-2007 08:21 AM |
| GZ curve | ivansalasj | Sailboats | 7 | 02-23-2005 12:51 PM |
| curve of areas | ibi | Sailboats | 4 | 03-08-2002 08:51 AM |
