| got problem to define angle in autohydro.. i got the problem to define the angle from 25p to 70stbd to perform stablity computation in autohydro version 5..previously i used the old of version 3..that's no problem..when i used the same command to the version 5 it got error with undefined value..i trying to apply the command as shown in Help (command directory) but it doesn't work.. Is anybody know how to solve this prob???? thanks a lot.. |
| Are u trying to perform IMO wind criteria? Maybe if you can post the syntax (command) concerned here and I'll take a look into it. When I upgraded from version 5 to 6.3, I also faced some problems with the old syntax. |
| yah..it's for IMO wind criteria..This is the command i used.. ANGLES -25, -20, ..., 70 thanks petlily.. |
| problem in Autohydro | saad | Software | 0 | 12-14-2008 04:30 AM |
| Skid Fin Angle or not to Angle? | dcrummett | Powerboats | 2 | 06-11-2008 03:29 PM |
| repowering problem: prop shaft angle >15 degrees | rdunncpa | Diesel Engines | 6 | 10-24-2007 05:35 AM |
| Relationship between angle of attack of keel and heel angle | stelios | Sailboats | 9 | 05-29-2006 02:14 PM |
| how to define a damaged condition in autohydro | hello | Software | 0 | 03-08-2005 07:31 PM |
