  #31
Old 01-07-2009, 02:01 PM
Previous Member
Rep: 0 Posts: 0
Originally Posted by Kudzu View Post
LOL, you obviously don't kayak much do you? ..........
Well not quite kayak but I do cover a lot of water under human power. I have a very good idea of what is sustainable by various humans. See attached.
Rick W
  #32
Old 01-07-2009, 05:38 PM
Kudzu Kudzu is offline
Rep: 10 Posts: 45
Interesting. I can't get the spread sheet to download though.
Still, the difference is those racing and those out just to be paddling. The people I am aiming this design at are in the 3.5-4 mph speed 90% of the time. These are people that take their boats out once or twice a month. Not athletes nor any desire to paddle fast for any length of time.
So that is why I used that speed. Maybe that is a mistake in Michlet? My thinking was optimize it at the speed it would be used at most of the time.
I ran one more model that looked pretty promising. I love the shape, similar to what I started with.
I ran it through FreeShips Kaper numbers and put it a spreed sheet with my existing design. I was surprised at the results. No difference in what I started with. The lines are almost on top of each other.
I put in the one where I let Michlet just run and it's a dramatic improvement, but I am not sure my target group would be comfortable in boat with that low stability. But it has peaked my interests.
I have one in the shop almost done with a little higher stability. Once I paddle it I will have a better feel for exactly what the numbers mean when your sitting in the boat.
Even if I have not improved my design I have sure learned a lot about Michlet and will continue to work with it and learn to use it better.
  #33
Old 01-07-2009, 05:58 PM
Previous Member
Rep: 0 Posts: 0
The bottom of your drag curve shows 3mph = 3.45kts.
3mph is 2.6kts. Not very fast and somewhat slower than 3.45kts.
Most untrained paddlers I see have little difficulty holding 8kph or 5mph for an hour or two unless they are on a 2m long sit-on. Then 6kph is about their limit.
The shape your are seeing is typical of the shape for a hull that is operating below the hull speed. As you approach hull speed or exceed it the ends tend to get fuller.
Rick W
  #34
Old 01-07-2009, 07:08 PM
Rep: 10 Posts: 45
3mph is 2.6kts.
I had to look that conversion up, must have multiplied when I should have divided. I created this chart for someone else and then recycled it. Thanks for pointing that out, I would have never noticed.
You must grow them stronger and leaner down under! I know a few paddlers that paddle at those speeds. Most are competitive people and do some racing. But the group I am aiming at couldn't or maybe wouldn't paddle at 5 mph for an hours time.
  #35
Old 01-07-2009, 08:00 PM
Previous Member
Rep: 0 Posts: 0
There are a few in the Over 50s group that I know can sustain 7kts on a surf ski. The younger guys are up around 8kts in an endurance event in calm conditions. These guys are fit but not quite world class.
The 70 plus grandmothers I have seen paddling will amble along quite happily at 8kph for hours. I guess a 70 yo woman paddling a kayak is not all that common though so they might be quite special.
According to the attached chart I am at the bottom end of untrained male at full-time rate. I am not overweight. In my defence I am on the mature side of 55yo. (The chart is from the xls file you could not open) At the 5 minute level I can match the bottom of the moderate. Peak power is back at the bottom of the untrained.
Rick W
Godzilla vandoren Software 57 09-23-2009 12:23 PM
Who Uses Godzilla? Guest625101138 Boat Design 14 01-13-2008 11:53 AM
Michlet and hard chines Windvang Software 5 12-17-2007 09:35 PM
"Hard Chines" DaveK Boat Design 34 02-25-2006 12:17 PM
Hard or soft chines & their effects on rolling Parke Brinkley Boat Design 3 07-22-2004 04:05 PM
