Old 03-28-2008, 12:31 PM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 316
Godzilla to freeship
After optimizing the vessel in Godzilla; is it possible to export the optimum ship to freeship ?
Old 04-10-2008, 06:13 AM
Protosys Protosys is offline
Rep: 10 Posts: 6
i think it records the data in the TXT file fsoff1.txt in the michlet root. you can now open surface on the freeship
Old 04-10-2008, 08:21 AM
Previous Member
Rep: 0 Posts: 0
Godzilla produces a hull offset text file that can be imported into FreeShip using the surfaces option.
You need to enter the correct number of waterlines and stations when you import. Also you need to set the hull values for length, beam and draft. If you do not do this to set the coordinate space you will get all stations showing on one side.
You may also need to do a bit of fairing as Godzilla could give you some lumps and bumps that typically do not contribute much. Hence if you have a lrage number of waterlines and stations there is a lot of work involved in fairing.
Rick W.
Godzilla vandoren Software 57 09-23-2009 01:23 PM
Godzilla/Michlet question coreym Software 9 02-23-2008 05:14 AM
Who Uses Godzilla? Guest625101138 Boat Design 14 01-13-2008 12:53 PM
Godzilla vs. Michlet LP Software 4 01-25-2007 04:58 AM
