Old 06-02-2010, 02:38 PM
bekster bekster is offline
GL Poseidon - Geometry import
Hi,
I know Poseidon is not really a design software but maybe there are some people around here that do know how to work wit it?
I have a Problem:
I want to import the Hull geometry from Delftship to Poseidon. Therefore I had to create an offset file just like its written in the description of the poseidon manual:
# Example file, in order to show the syntax
PRINDIM LPP 195.4 LWL 195.4
PRINDIM B 29.8 H 50.5 T 10.1
LFRAMETAB RANGES 4 FPP 190 REFFRAMENO 246
-7 720
4 800
47 790
255 790
FUNCELE SHELL FRAMENO 5 POINTS 17
0000.0 9461.2 LINE
1425.1 9617.6 LINE
4102.1 9970.3 LINE
6258.6 10315.8 LINE
8060.2 10679.9 LINE
9955.3 11209.4 LINE
10668.5 11465.4 LINE
11827.8 12021.6 LINE
12736.9 12631.7 LINE
13191.3 13025.3 LINE
13502.8 13336.3 LINE
14023.6 13980.9 LINE
14564.4 15011.0 LINE
14780.9 15755.6 LINE
14886.7 16555.2 LINE
14900.0 16978.8 LINE
14900.0 21400.0 LINE
When I use this example offsets, poseidon creates the frame #5 without problems...
But when I want to import my file, wich looks exactly the same but with different offsets, poseidon says "syntax error" (unknown keyword)...
even when i reduce it to only 1 frame like in the example, it still wont work...
this is how the offsets of one frame of my model look like:
0000.0 0000.0 LINE
10621.0 0200.0 LINE
11691.0 0400.0 LINE
12153.0 0600.0 LINE
12492.0 0800.0 LINE
12773.0 1000.0 LINE
13001.0 1200.0 LINE
13187.0 1400.0 LINE
13342.0 1600.0 LINE
13467.0 1800.0 LINE
13567.0 2000.0 LINE
13648.0 2200.0 LINE
13714.0 2400.0 LINE
13768.0 2600.0 LINE
13811.0 2800.0 LINE
13840.0 3000.0 LINE
13850.0 3200.0 LINE
13850.0 3400.0 LINE
13850.0 14600.0 LINE
Has anybody any ideas why those wont work?
Thanks alot!
Old 06-03-2010, 09:51 PM
PhotoBoatGuy PhotoBoatGuy is offline
Rhino fanatic
Rep: 17 Posts: 22
I don't know the Poseidon system, but a question of a more general nature arises. In the example from the software, there is a 9-line header, followed by an empty line, followed by the offsets.
What you showed for your example was just the offsets for the frame. Could it be that you did not include the header?
Also, do you know the meanings of all the elements of the header? Perhaps one of them is inapplicable to the geometry. Error messsages don't always accurately describe the true nature of the problem
Just a couple of suggestions.
Another item that may give you an idea: For years I've worked with AutoCAD, using attributes in blocks. When you extract the data from the attributes, you must specify a template file for AutoCAD to use for extraction. If you leave a line feed at the end of the last line of the template file, the file won't work and you'll get a very cryptic error message that does NOT tell you that the problem is that extra carriage return. You might check for this same type of thing in your inputs.
Best of luck
Cliff W Estes
Old 06-12-2010, 04:16 PM
Perm Stress's Avatar
Perm Stress Perm Stress is offline
Rep: 323 Posts: 523
I do much of my work in Poseidon.
Error messages you refer to most probably stem from reasons already mentioned in previous post.
In your effort to sort this out, keep in mind that header of file contain important general information about ship, like LPP, and parameters of "frame table - x direction". Last time I had problems with import, they were connected with x-frame table .
I would also note, that Poseidon demand close to absolute accuracy in every detail, in order to work properly (not only in geometry import).
Once I did come to aphorism "Poseidon is created by MATHEMATICIANS!"
Keep this "mathematical nature" in mind, save your file often, and make a spare copy before starting ANY operation new for you.
good luck!
All the stresses in my designs are 95% of permissible.
Propeller Geometry conceptia Props 5 04-27-2010 01:26 AM
New models of POSEIDON burak.acar Boatbuilding 0 10-26-2006 07:36 AM
Poseidon Yacht Design Co. Ltd. burak.acar Services & Employment 0 08-01-2006 08:04 AM
POSEIDON Yacht Design Co Ltd burak.acar Marketplace 0 08-01-2006 08:02 AM
geometry of sailing Sailboats 8 10-12-2002 10:58 AM
