| GHS export , when the hull has more than one surface!!! It is very easy to export GHS file by rhino 3.0 when the hull is composed of only one surface (hull made by maxsurf ) but if there are more than one surface, then problem arises, when I give AttachGHSData command; then in the select geometry option , when I try to select the hull , only a part of the hull is selected, and the complete hull (half) can not be selected; I am facing a great porblem for this , to analyze my design. can you plz give me solution how can I analyze stability of ships who are composed of more than one surface in maxsurf? thanks! -pavel |
| You need to go to the main "Hull Data" list, then use "add hull object" then you can add as many objects (surfaces) as you want. Tim B.
| I found no words named "hull data" or " add hull object" when I type "attachghsdata" then a windo comes , then clicking on the hull, I get a option named " add part" and when I click on the hull a single portion of the hull is only selected, and then again cilicking on the hull name i get a option named " add components" by adding componants like this; I get a ghs data which is of errors,,, please tell me what I have to do! thanks! |
| that was what I meant. It should work fine. Tim B.
| no;;;;;;by my hull seems to be broken in many parts when I see it in "deadweight". I am not able to export a GHS file which is nice and continious by rhino 3.0 for one surface hulls it is working;;;;;but for more than one surface , it is giving bad!!!! ![]() |
| can you please give me a good solution , how can I now export a good GHS ? GHS export is now very important for me, i have to analize the stability of the hull which I have designed for my design project by maxsurf. please give me solution how I can export GHS from the hull which is more than one surface!!!!! thanks! |
| Have you tried working with a single polysurface, instead of a lot of different surfaces? This can sometimes clean up export problems in Rhino with other formats, it might work here too.
| I have joined the surfaces by "merge" commande ;;;;;;but after that also;;;; ghs export is not being fairly! I am afraid about that. Is there no solution for it????? |
| Hi Pavel, Do you have a sample Rhino model that I could look at in order to try and help? Thanks, -Steve |
| @ steve;;; yes,, but how can i send it to you? thanks! |
| you can send it to steve@mcneel.com |
| @ steve,,,, I have sent the rhino file to you by my mail adress pavel915@gmail.com please check it and telll me how can i solve my problem for this |
| Hi Pavel, I sent you a solution to you by email. If you don't get it, please let me know. Thanks, -Steve |
| thanks steve,,,,,, verymuch by your reply I have understood my problem , and it is now ok to me! thanks! |
| efficiency of surface drives and surface piercing propellers | David Knight | Powerboats | 7 | 09-24-2009 04:10 PM |
| rhino3d 2.0 ghs data export | pavel915 | Software | 9 | 12-09-2006 10:29 AM |
| Freeship chines export to 2D and 3D | Drysideup | Software | 2 | 01-09-2006 09:04 AM |
| hull surface at rhino | gunther prien | Software | 1 | 08-03-2004 10:32 AM |
| about Pro/E data export? | Software | 0 | 05-23-2002 09:22 PM | |
