| Freeships control net ? Anyone have any ideas about organizing the control net in Freeships ? I am having some trouble fairing some areas of a hull. Frank |
| Yeah, some ideas... But I fear you have to be more specific, post your hull model or a screenshot and some detail on what you want to improve.
__________________ All the best, Olav GER-1045 ____/)_/)/)___ |
| I think a more general idea of how different people set up the control net . The number of vertical lines , angles , spacing, and way to get the best results. F |
| As a general rule, less is better. I've learned that a finer net gets difficult and too time-consuming to fair. |
| Thanks, Frank |
| On a ply chine design i think it would be good to orient the vertical edges so that they follow the conical projection. That would be to align with the apex of the projection . Of course this location can only be estimated , as there is no guide. Doing this will change the point spacing and make fairing more difficult . Do you trust the developments of flat panels that come from Freeships ? My experience would lead me to believe that it is not perfect. |
| Another question is what to do when bulk heads and interiors are added to the design . Now the nicely faired design is all messed up and you have to start again. Is there a function that will note the original location of the faired net. I know that there is a note of lines when importing lines from out side ,but can they be reset ? F |
| frank, i only used printed paper and that was pretty accurate but people do build boats using freeship did you try that scow junk in your gallery, looks it should fold nicely together start small check and go bigger, why the scepticism? |
| Freeships lines ? | frank smith | Software | 13 | 11-05-2010 01:18 PM |
| Bd.net blocked, help please! | apex1 | Forum Questions and Suggestions | 30 | 09-21-2010 05:50 AM |
| How much help did you get from Boatdesign.Net? | nukisen | Open Discussion: All Things Boats & Boating | 26 | 02-14-2010 03:04 PM |
| Surfing the net | MikeJohns | Open Discussion: All Things Boats & Boating | 1 | 07-26-2006 06:45 AM |
| BoatDesign.net | Nomad | Open Discussion: All Things Boats & Boating | 17 | 02-08-2003 06:49 AM |
