| Freeship trim problem Hello everyone, I'm an italian student of Politecnico (Milan). I have to project a new flyingboat with the tecnology of 1935 for a course of mine. One of most difficult threads is for me the definition of the hull. I'm trying to make some tests with Freeship to determine the planing resistance for the boat but the trim angle is driving me crazy because is too low... in addition I get an issue for lambda in the results windows: Lambda is outside valid domain 2,0 ... 5,0 I'm not sure of the value of LCG but I think that should be the entire boat center of gravity value. Thanks for the help!!! I forgot the results log: Final calculations of resistance and power for planing ships Project : Designer : Filename : C:\Documents and Settings\Mattia\Documenti\Dropbox polimi\Dropbox\Scafo\scafo catia-freeship\scafomesh3.fbm Design length : 22.000 m Design beam : 3.760 m Design draft : 1.200 m Midship location : 11.000 m Water density : 1.025 t/m^3 Appendage coefficient : 1.0000 Date : 27/08/2011 Time : 19.21.43 ---------------------------------------------------------------------------------- Input variables Hull Effective waterline length : 19.618 m Beam on waterline : 3.304 m Draft hull : 1.131 m Wetted surface area : 59.37 m^2 Prismatic coefficient : 0.5242 Displacement : 29.12 t Deadrise amidships : 25.000 degr X of CoG : 12.185 m Midship area above waterline : 0.00 m^2 Roughness coefficient *10^3 : 0.000 Maximal speed : 30.00 knots Angle between Thrust and Keel lines : 4.00 degr Distance between Thrust line and CoG : 0.150 m ---------------------------------------------------------------------------- Final calculations of resistance and power for planing ships by D.Savitsky +-------+-------+-------+---------+---------+---------+---------+ | Vs | FrB | Tau | R_f | R_p | R_t | Pe | | [kn] | - | [degr]| [kN] | [kN] | [kN] | [kW] | +-------+-------+-------+---------+---------+---------+---------+ Lambda is outside valid domain 2,0 ... 5,0 | 18.81 | 1.70 | 1.30 | 10.594 | 6.564 | 17.158 | 166.038 | Lambda is outside valid domain 2,0 ... 5,0 | 19.93 | 1.80 | 1.31 | 11.716 | 6.640 | 18.356 | 188.198 | Lambda is outside valid domain 2,0 ... 5,0 | 21.05 | 1.90 | 1.33 | 12.871 | 6.721 | 19.592 | 212.147 | Lambda is outside valid domain 2,0 ... 5,0 | 22.17 | 2.00 | 1.34 | 14.062 | 6.802 | 20.864 | 237.926 | Lambda is outside valid domain 2,0 ... 5,0 | 23.29 | 2.10 | 1.36 | 15.278 | 6.889 | 22.166 | 265.538 | Lambda is outside valid domain 2,0 ... 5,0 | 24.41 | 2.21 | 1.38 | 16.516 | 6.980 | 23.495 | 294.983 | Lambda is outside valid domain 2,0 ... 5,0 | 25.52 | 2.31 | 1.40 | 17.779 | 7.071 | 24.850 | 326.298 | Lambda is outside valid domain 2,0 ... 5,0 | 26.64 | 2.41 | 1.41 | 19.066 | 7.162 | 26.228 | 359.493 | Lambda is outside valid domain 2,0 ... 5,0 | 27.76 | 2.51 | 1.43 | 20.355 | 7.264 | 27.619 | 394.446 | Lambda is outside valid domain 2,0 ... 5,0 | 28.88 | 2.61 | 1.45 | 21.670 | 7.360 | 29.030 | 431.313 | Lambda is outside valid domain 2,0 ... 5,0 | 30.00 | 2.71 | 1.47 | 22.979 | 7.466 | 30.445 | 469.866 | +-------+-------+-------+---------+---------+---------+---------+ C.W.F.Hamilton & Co. type of waterjet calculation, according to [1,2]: Vs = 30.00 kn = 15.433 m/s Nwj = 1 Ct = 7.045 Cp = 18.444 EtaW = 0.382 Power (P) = 1230.03 kW = 1671.24 BHP ATTENTION !!! Power is out valid domain 30 ... 400 BHP per unit for used diagram. Impeller Type: 9 11 12 13 14 15 RPS (n) = 85.4 82.4 78.7 75.8 74.5 73.1 RPM (n) = 5121 4941 4721 4550 4473 4386 Nwj = 2 Ct = 3.523 Cp = 7.566 EtaW = 0.466 Power (P) = 504.57 kW = 685.56 BHP ATTENTION !!! Power is out valid domain 30 ... 400 BHP per unit for used diagram. Impeller Type: 9 11 12 13 14 15 RPS (n) = 63.4 61.2 58.5 56.3 55.4 54.3 RPM (n) = 3805 3672 3508 3381 3323 3259 Power*Nwj = 1009.15 kW = 1371.12 BHP Nwj = 3 Ct = 2.348 Cp = 4.639 EtaW = 0.506 Power (P) = 309.36 kW = 420.33 BHP Impeller Type: 9 11 12 13 14 15 RPS (n) = 53.9 52.0 49.7 47.9 47.1 46.1 RPM (n) = 3233 3119 2980 2872 2823 2768 Power*Nwj = 928.08 kW = 1260.98 BHP Nwj = 4 Ct = 1.761 Cp = 3.332 EtaW = 0.529 Power (P) = 222.24 kW = 301.95 BHP Impeller Type: 9 11 12 13 14 15 RPS (n) = 48.3 46.6 44.5 42.9 42.1 41.3 RPM (n) = 2895 2794 2669 2572 2529 2479 Power*Nwj = 888.94 kW = 1207.81 BHP REFERENCES: 1. Donald M. MacPherson.- A Universal Parametric Model for Waterjet Performance, HydroComp, Inc., Presented at FAST-99, Aug 1999. 2. HydroComp, Inc., "Waterjet Data Files for NavCad", HCI Report No. 119, December 1997. Copyright (c) 2008-2010, Timoshenko V.F. |
Regards |
Deadrise amidships : 25.000 degr X of CoG : 7.185 m Midship area above waterline : 10.00 m^2 Roughness coefficient *10^3 : 0.400 Maximal speed : 30.00 knots Angle between Thrust and Keel lines : 4.00 degr Distance between Thrust line and CoG : 0.150 m ---------------------------------------------------------------------------- Final calculations of resistance and power for planing ships by D.Savitsky | Vs | FrB | Tau | R_f | R_p | R_t | Pe | | [kn] | - | [degr]| [kN] | [kN] | [kN] | [kW] | Lambda is outside valid domain 2,0 ... 5,0 | 18.81 | 1.70 | 4.01 | 7.116 | 20.342 | 27.458 | 265.701 | Lambda is outside valid domain 2,0 ... 5,0 | 19.93 | 1.80 | 4.16 | 7.744 | 21.100 | 28.845 | 295.725 | Lambda is outside valid domain 2,0 ... 5,0 | 21.05 | 1.90 | 4.36 | 8.366 | 22.134 | 30.500 | 330.251 | | 22.17 | 2.00 | 4.55 | 8.982 | 23.077 | 32.059 | 365.590 | | 23.29 | 2.10 | 4.72 | 9.592 | 23.943 | 33.535 | 401.732 | | 24.41 | 2.21 | 4.87 | 10.198 | 24.723 | 34.921 | 438.432 | | 25.52 | 2.31 | 5.00 | 10.804 | 25.397 | 36.201 | 475.336 | | 26.64 | 2.41 | 5.11 | 11.411 | 25.969 | 37.380 | 512.335 | | 27.76 | 2.51 | 5.20 | 12.027 | 26.418 | 38.445 | 549.071 | | 28.88 | 2.61 | 5.27 | 12.656 | 26.745 | 39.401 | 585.403 | | 30.00 | 2.71 | 5.31 | 13.301 | 26.954 | 40.255 | 621.263 | Calculated FrV=2.810 +------------------------------------------------+ | Parameter | Calculated | Optimal | +------------------+---------------+------------+ | L/B | 5.938 | 5.750 | |Cg=D/(Rho*g*B^3)| 0.807 | 0.487 | | Beta | 25.000° | 15.707° | | Xg=LCG/L | 0.366 | 0.404 | +------------------------------------------------+ As can be seen from the table, we must reduce the L / B Deadrise amidships (Beta) and D. And use a newer version Freeship Plus 3.24 + |
| Thank you very much for the fast answer. I'm going to try right now |
| I'm sorry if I bother you again but I have some questions: Why did you put 7.185 m as LCG? Is it the center of gravity of all the flying boat, isn't it? In fact if I take LCG =12.185 that is the CG of the seaplane the trim is quite low (around 1.4). Unfortunately I cannot touch the values of the total lenght and of the beam that are fixed in order to project constraints to B=3.76 and L=22m ... How can I reduce lambda (that is LCG/Lwl isn't it?) without modifying these parameters? Last question: how is Cg calculated? Because I cannot find the value of D that returns me the same result of the program. Thank you again for your patience. PS. I downloaded the new version of freeship... that's quite better and a little faster, thank you! |
| Hi, Hydronship... err, umm, FREE!ship Plus 3.24+ TEST is out. Not sure if it will have more than what is listed here or help you get calcs you're after: http://hydronship.net/stati/idnews/59 I'm excited and will be checking it out on my lunch break! Cheers Last edited by CmbtntDzgnr : 08-29-2011 at 02:07 PM. Reason: corrected name of FREE!ship... |
| Well, I'm happy that Fung-Leibman resistance for naval vessels calculation engine works. My one problem that I need to resolve is correcting my Ie (bow entrance angle) to 2.7 deg from the current 89.x degrees. (When checking the box "extract data from current hull", that value appears, and when I deselect it and alter it to become 2.7 (higher than the 2.6, but lower than the 31.73 domain range), the resistance and power values change to a Pe kW 38141 and RT kN of 2247, from a Pe kW of 1,300,000 and RT kN of 80790.). I'll just adjust the bow area to get that value to correct so the calcs become favorable without my manually adjusting the input variables. By the way, my hull is around 166.9x18.35x7.8 m. The Cp is 0.6011. The Cb is 0.3318. Cwp is 0.7678. When i change the resistance calc engine to planing hulls, and set speed higher than 44, say, to 44.5 kts, I get some results to appear. Setting the speed to 54 knots generates "Lambda is outside valid domain 2,0 to 5,0." But, interestingly, the Rt is around 5158 kN and Pe is 143302 kW. To get the value of 143000 kW in Fung-Leibman, I would need to set the speed to 43 knots. the Rt pretty much corresponds. This is an incredible, generaous, great program, even though I'm not an engineer and not capable of fully appreciating the really hard work programmers and architects go through to arrive at or rationalize useable output from software. |
| Stern Down Trim Problem | oatsandbeans | Sailboats | 6 | 09-04-2009 06:10 AM |
| trim problem | phil74 | Propulsion | 4 | 08-29-2007 03:57 PM |
| Trim gauge problem | thebassn8tr | Powerboats | 0 | 09-29-2006 07:39 PM |
| Freeship Hydrostatics Trim | goolawah | Software | 2 | 08-22-2006 04:30 PM |
| I/O Trim Problem, please help. | In The Zone | Powerboats | 3 | 08-08-2005 01:14 PM |
