Old 12-04-2008, 04:24 AM
thuffam thuffam is offline
Rep: 10 Posts: 7
Freeship questions (nesting and creating bulkheads)
Hi there
I am using Freeship (Free!Ship) to design a small outrigger/canoe hull but have come stuck...
1) When I try to create panels for the bulkheads, the side panels of the hull change from a nice curve (end-to-end) to straight/angles (straight lines between the bulkheads/frames). Is there a way to keep the sides curved?
2) Is it possible, in Freeship, to do nesting for standard plywood sheets? I've used the Develop Plates function, but this assume infinate size material sheet - so how could you nest for plywood of 1200x2400? Or is there some other software I'd need for this?
Or is there a better software package I should be using?
Thanks very much
Tim
Adding Bulkheads 'n stuff to Freeship model lewisboats Software 28 03-08-2008 09:29 AM
creating cabin tops in freeship rapscallion Software 5 11-07-2007 02:12 PM
FreeShip Questions jprev Software 2 03-22-2006 06:55 AM
Freeship to Michlet questions Deering Software 2 12-09-2005 10:49 AM
Creating nesting and NC cutting files airtoad Software 5 11-15-2004 04:38 AM
