Old 03-21-2006, 07:28 AM
jprev jprev is offline
Rep: 10 Posts: 37
FreeShip Questions
In FreeShip how do you enclose a transom? With extrude? Second, how do you tell FreeShip that the transom on a double ended canoe is closed. Thanks!
Old 03-21-2006, 08:43 AM
LP's Avatar
LP LP is offline
Rep: 370 Posts: 640
You can use the extrude command to start the tramsom and then set the newpoints to a Y value of zero. On a canoe stern, just set the aft set of points to a Y value of zero.
Freeship is just looking for leak points when it is doing hydrostatics. All Y points on centerline, below the waterline, must be set to zero or you will have a leak and the hydrostatic calculations don't work. Leaks are indicated by a different color of control point.
LP
God bless the open minded people of the world. LP
Old 03-22-2006, 06:55 AM
Rep: 10 Posts: 37
Thanks!
FreeShip lewisboats Software 6 08-03-2009 12:52 PM
Freeship question Windvang Software 5 01-10-2006 09:48 AM
Freeship to Michlet questions Deering Software 2 12-09-2005 10:49 AM
FreeSHIP 2.1 lewisboats Software 5 11-06-2005 06:35 AM
