Old 11-10-2007, 08:17 PM
rapscallion rapscallion is offline
Rep: 129 Posts: 412
Freeship question.
I have 3 hulls in freeship - and I'm trying to build a trimaran. All of the hulls are the same size. They were mirrored into existence. How do I shrink the amas?
http://janetcg32.blogspot.com
Old 11-10-2007, 09:10 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Try using the Transform > Scale command on the layer that contains the amas. If they're on a separate layer from the main hull this should work.
Old 11-11-2007, 11:47 AM
Rep: 129 Posts: 412
Yes, that's the thing. All of the hulls are in the same layer after the mirror. I'll look into trying to change that. I don't know how to do that yet.
The thing is that would give me identical hulls but a different scale. What if I wanted a length to beam ratio of 10.5 to 1 on the main hull and 12 to 1 on the amas?
Old 11-11-2007, 05:05 PM
Previous Member
Rep: 0 Posts: 0
Export the whole thing as a .part and import the same .part into different layers. You can then cut out different bits in the two layers so you amas in one and main in the other.
You can scale by different amounts on each axis.
You can also choose a layer to be symmetrical or not. You can choose which layers are part of the hydrostatics as well. It is good to use different layers for different bits and name them accordingly.
Rick W.
Freeship question jim lee Software 5 10-16-2007 11:54 AM
freeship question pavel915 Software 7 08-01-2007 01:58 AM
another freeship question Redsky Software 2 07-24-2006 03:43 AM
Another FreeShip Question jprev Software 3 03-27-2006 12:28 PM
Freeship question Windvang Software 5 01-10-2006 08:48 AM
