Old 07-03-2007, 11:26 AM
alexlebrit alexlebrit is offline
Rep: 16 Posts: 122
FreeShip putting an end on a cylinder - how?
Grr, it's maddening, I'm trying to put a nice flat face on each end of cylinder in FreeShip and it keeps bringing it in to a point, but not even a nice point like a pencil, a weird distorted in and out point.
All I want is a nice cylinder 5m long with a radius of 0.25m sealed at both ends, can I do it? No.
Grrr to FreeShip.
Old 07-03-2007, 01:46 PM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
saw your pencil tips also but stay cool and you can do it.
extrude, add vertexes, set corners and crease, done in a minute!
getting the hang of it takes some routine.
Old 07-04-2007, 05:25 AM
Rep: 16 Posts: 122
I don't even seem to have those options, I have to say whilst FreeShip is great in some ways, in other ways it's a real pain in the .... well you know.
Maybe I'll just stick to a pencil and paper?
Old 07-04-2007, 05:56 AM
PI Design's Avatar
PI Design PI Design is offline
Rep: 309 Posts: 604
Freeships great for hulls, and the keel wizard is neat, but its not really intended to be used for other appendages. Best to use Rhino or some other 3d CAD for that.
Old 07-04-2007, 07:46 AM
Olav's Avatar
Olav Olav is offline
cand. arch. nav.
Rep: 337 Posts: 198
Alexlebrit,
making such a cylinder is easy:
1. Tools --> Add cylinder:
2. Input particulars:
3. Click "OK" and mark the edge(s) of one side of the cylinder:
4. Extrude the edge to a handy dimension (here: 1m):
5. Mark all points of the new outer edge and set y and z to zero:
6. With the points still selected, move them back using Transform --> Move:
7. Done! (Repeat steps 3 to 6 with the other end of the tube accordingly.)
All the best, Olav GER-1045 ____/)_/)/)___
Old 07-05-2007, 04:59 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Nice
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 07-06-2007, 04:47 AM
Rep: 16 Posts: 122
Olav, if you were female I'd marry you, and if I was I'd have your babies. Thank you very very much.
Old 07-06-2007, 05:30 AM
Raggi_Thor's Avatar
And I suppose the kids would be talking English, French, German and Norwegian before they started sailing around the world.
www.MBOATS.no
has anyone tried putting a cabin on a whaler hull? bigisland Fiberglass and Composite Boat Building 2 03-06-2007 02:03 AM
Putting it all together. LP Powerboats 8 02-24-2007 04:00 AM
putting casting deck in a tri-hull mkkoyboy69 Fiberglass and Composite Boat Building 1 04-27-2006 03:38 PM
Putting Fastship DWG on WEB S Hondros Software 0 01-03-2006 04:37 PM
Putting togather a boat need help gincrew Boat Design 3 11-11-2005 09:40 PM
