| Freeship offsets excel import problem Hi all, I made the attached txt file to import in freeship. The result is a nightmare. I ve tried several times, read the manual, read the forum, but no success. In the xls file you can see the conversion excel sheet and the original table of offsets that I want to import. Can someone tell me what I am doing wrong? Many thanks, Henk Siereveld |
| Hi, Can you tell us a little about the hull? Are these offsets for chines? Or is it for shapes (regular curved hull, no chines)? It looks like your table of offsets might be using the waterline for the baseline. But after playing around a little with the dimensions of the control points that also seems like a doubtful theory. So any clues you might provide might help arrive at a solution. |
| Just have a look ate the middle column of your text file. The y-coordinates (beam of each station at a particular waterline height) start with a value larger than zero, it should be zero. Then, as the waterline heights increase your beam first decreases to zero and then increases again. It looks you made an error while transferring your offsets to the file. |
The Excel input data is obviously not correct. At every station you have zero value for the WL 36" and WL45" coordinates. Also your offset table only has the sides of the boat above the waterline. You have not included and of the skeg or keel info in your tables. I have attached an offset file for the underwater section of a slender hull. If you import this into Freeship it will give you an idea of what you should be looking for. Rick W. |
| Freeship IMS offset file import - files wanted | DuncanG | Software | 0 | 12-08-2007 10:02 AM |
| How do I import offsets into Freeship? | alexlebrit | Software | 5 | 05-26-2007 06:44 AM |
| FreeShip/DelftShip - Import Offsets | colinstone | Software | 0 | 04-14-2007 03:37 PM |
| Importing tables of offsets from Excel to Freeship | Troutcatcher | Software | 2 | 12-19-2006 12:20 PM |
| Import Linesplan DXF to FREESHIP? | internetturk | Software | 18 | 10-13-2006 05:22 AM |
